Question about Microsoft Windows Vista Business Edition for PC
Error Code 2203. This I get when I try to uninstall or install
I tried to delet a document and some programms I dont need and I keep on getting error 2203. Please advice on solving this problem. I use Windows Vista Business build 6001
  • 431 Answers
Hi I am Vortash ...I have never used or seen this version of window I am afraid however I cant think it is that much different in it's basic functions to Ordinary Vista Beta systems . So with that in mind I ask this has it got a user account administration function the same as vista home editoin if so turn it off and try again you may have a firewall or program conflict with this .. Have you tried asking microsoft support .. and finaly when did it start to do this recently or has it always done it what was the latest program you have installed before the problem started is it causing a conflicts hope this helps Regards Vortash ?
Posted on May 15, 2009
I am getting this error when trying to install anything on my win 7 ultimate. is there anything i can do to fix this? Says exactly this: "1152: Error...
1- Uninstall all the programes in control panel which you think you don't require
2- delete all leftover folders in program files outspark etc.
3- click start > run > type %temp% and delete ALL the files in that folder
( There will be like 3-4 u can't delete, dont worry about it ) also make sure you uninstall and delete the launchers.
4- Re download the PROGRAME ( INSTEAD of Saving it to DESKTOP, Save it somewhere else Like My Documents, Run it, And there you go problem solved.
At least that is how it worked for me, every time i was having that error i was saving it to desktop, after i did all the steps before and changed the location to my documents, it installed without any problems.
Aug 11, 2011 | Computers & Internet
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
Fatal error during installation
This could be issue related to Service pack, Windows Installer and also with Admin rights on the PC
TRy this Document :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c00367809
Jun 22, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
Error code 2203 when I try to load M/S Office 2007
To resolve this behavior, grant the System account Full Control permissions to... loadTOCNode(1, 'resolution'); To resolve this behavior, grant the System account Full Control permissions to the folder that contains the administrative installation point.
Apr 30, 2009 | Computers & Internet
Cannot uninstall or install HP scanjet G2410
I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
Apr 08, 2009 | HP Scanjet 4470c Flatbed Scanner
Fatal error 2203
Editing the registry is risky. Use these instructions at your own risk.
First do a normal uninstall of your HP printer
If you have trouble installing officejet j4580, you may need to edit the registry and remove all HP items. Make sure you first go to control panel and delete all installed hp printers. Then go to Windows Explorer and delete all hp folders. Save a backup copy of your registry. Then find all HP registry keys and delete them.
Then restart your computer. Download the latest printer package from the HP site and save to a folder in your Documents. Then install the package from the download.
bvrock41
Nov 20, 2008 | Office Equipment & Supplies
GETTING A FATAL ERROR MESSAGE AND MSI CODE 2203 ON HP L 7590 prin
Visit the below web link and perform the steps provided in the document
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00459898
if the issue still persists,
perform uninstallation and installation that should resolve the issue
Nov 15, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
WHY Cant I get Microsoft Word to print?
Best solution is you still have FREE tech support for your computer and also your Office Enterprise 2007. Call Microsoft
Dec 04, 2007 | Microsoft Office Professional 2007 Full...
BUS DEVICE RESET FUNCTION
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Microsoft Windows Vista Business Edition for PC Logo
151 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
