Question about Samsung D840 Cellular Phone
CANT DIAL OR RECIEVE!
HI THERE I HAVE SWITCHED MY PHONE ON AND THERE IS A SYMBOL AND IT SAYS NO SERVICE AND I HAVE TAKEN MY PHONE VARIES PLACES CHANGED SIM AND STILL NO LUCK
WHAT SHOULD I DO
THANKS
    Brigadier General:
  • 7,752 Answers
Try *2767*3855#
Posted on Feb 16, 2008
Can make calls on my samsung b2100 but cant recieve, saying phone is switched off.
Network problem or software problem, contact your service provider or flash the phone with Computer.
Aug 11, 2011 | Samsung B2100 Cell Phone
My phone just has a looking for service. . symbol
Hello.
there are two ways of solving your phone problem
1.turn off your phone for some seconds then put on again.
2. What you have to do is to get a friend/relative phone to contact your service provider.
Best of luck.
Mar 12, 2010 | Cell Phones
Sony Ericsson K800i cant make of recieve calls, and inactive sim!
mikey....not to worry after reading your problem i found it a software problem ......give that phone to your retailer for software formatting and every thing will be ok.
Feb 18, 2010 | Sony Ericsson K800i Cellular Phone
I have a symbol of a phone with a red slash through it HELP !!
HI. This is a no service signal. There are two reasons for this type of symbol. The first reason will be that your service provider has canceled your service for some reason. I would contact this provider for further discussion if this is the case. Secondly, this may be a severed internal antenna connection, due to a cold solder break between the board and antenna connection points. if this is the case, you will need to have this unit service asap, if possible.
**((A highly uncommon issue could also be that the NAM or PUK codes have been changed inadvertently. Although uncommon, this can happen by accident))
Sep 11, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Cant recieve text messages on at&t motorola c168i
there are a few reasons that could be causing this.
1. You may have changed the message center routing number.
* Go to messages - options - message setup - text messages - profile - SMS settings(should be check marked, if not select activate) - Customize
* The message center number should be +13123149810(plus must be entered....hold 0 key for plus)
2. Text messaging pay per use has been taken off your account. dial 611 from your phone or 1-866-246-4852 (after hours call 866-801-3600) from another phone for customer service. request pay per use to be added to your phone, or purchase a messaging plan.
These should cover it. Make sure to power you r phone off and on after any changes.
Dec 21, 2008 | AT&T Motorola c168i Pay-As-You-Go Cell...
Lexmark printer 8350
Okay for starters, you need to check to see if that fax machine is automatically answering the phone when it rings. you can check to see if it is trying to recieve by call that phone number from another phone and listen if it answers and when it does, does it make a high pitched squelling sound that varies in pitch.
if it does then it should be working ok, if not then you must program your recieve mode to automatically answer.
you can also check to see if it's sending by doing the opposite: put a sheet of paper in the machine to fax and dial your cell phone or other number, when it rings pick it up and listen for the high pitch squeel, if it works then your fax is working properly.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Cant hear when i am called
just go to the expert technician or go to show room... may be the water has entered to speakers also if possible try drying up it by hair drier if u r afraid means(remember cellphones must be switched off & battery must be remove dnt heat ur cell phone do it by removing panels only by hair drier by mild hot air) go to show room they will do it if not possible they change the speakers...
Feb 05, 2008 | Nokia N72 Cellular Phone
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Keypad is frozen, cant dial out or recieve any calls
PSYCHMAJOR - take the phone back
guest - replace the flexcable
Sep 21, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Samsung D840 Cellular Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
