Question about Koiiler 9696-C Car Audio Amplifier
Does my amps red light mean stop
My friend hooked my amp up reversing the positive and negative cables i saw a flash from the amp and smoke,but the wierd thing is it didnt blow a fuse and i cant see any damage but do see the red light that i guess means protect mode. just kinda looking for hope or away to maybe save it from the trash.
  • 3,267 Answers
The red light is for overload. Even though it has not blown any fuses but its definitely fried some capacitor,diodes,etc. If its still giving you sound output, make sure that your equipment is properly grounded before you start using it.........sodeep
Posted on May 15, 2009
2006 Honda Nighthawk 250 hooked up my battery charger backward
Hi, Roger if your battery out of your bike when it is completely dead and you hook up the battery charger backward your battery will charge fully except the poles will be backward, the Positive pole is now the Negative pole and the Negative pole is now the Positive pole. If you install the battery not knowing the poles have been reversed you will blow the main circuit fuse or circuit breaker on the bike.
If you tried charging the battery while it was still hooked up to the bike it will do the same thing to the fuse or circuit breaker in the battery charger. Most battery chargers have some type of warning light or buzzer alerting you to the fact that the cables are hooked up backward.
If your battery is fully charged backward take it out of the bike hook it to a headlight and let it drain until the voltage reads zero, this may take a couple of days, then recharge it slowly with a trickle charger or a regular battery charger at 1 or 2 amps for 24 hours and you will be good to go.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Reversed Battery Polarity Need Help Bike Won Start Now Honda Motorcycles...
Battery Backwards Damage and Fix
Honda TWINSTAR 250 Service Repair Maintenance
https://www.partsfish.com/page/oem-parts-for-honda
http://owners.honda.com/assets/OWNERLINK/model/own_man/powersports/2004/2004_CB250.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 30, 2018 | 2006 Honda Nighthawk 250
Why is induction motor saw blowing fuse shortly after starting?
If it is still trying to run as a DC system, it might be that the positive and negative are reversed.
May 03, 2014 | Saws
Car starts off jumper cables
First-- the negative cable from the charging vehicle ,
does NOT go to your battery,it goes to the engine block
Only the positive cable goes to the vehicle being jumped
You will have a large 100 amp fuse or fusible link, that may look like a fuse or a hidden buss bar
You will need a wiring diagram to find a test point or place to open
things up
You may have fried several feature, once you get it to start & is drivable
Mar 15, 2014 | Nissan Pathfinder Cars & Trucks
Battery fuse blows when i hook up new battery
With battery disconnected, take a meter reading [resistance / ohms] across the battery leads. It sounds like you have close to a short circuit in your primary charging/supply circuit. 0.6 ohm will take out a 20 amp fuse. Ohms law I = V/R. Quite a few other factors to take into account but you'll have to find what's causing the low resistance.
Nov 30, 2013 | 2005 Harley Davidson FLHRS - FLHRSI Road...
I recieved an item that doesn't work
It sounds like you didnt hook the negative to the negative and the positove to the positive. Thats the only way that will happen. Or if you put to big of speakers on the amp
May 04, 2013 | Car Audio & Video
Light comes on: Traction engaged and goes on and off. Also the anti-loc traction control light comes on and off on Cadillac 1997
My friend; Try this; Check the fuses / relays boxes in both cabin & engine compartment. Make sure there is no burned fuse or relay. U can check them visually & or using digital multi tester DMM. Check the brake peddle switch. This system {TCS} hooked up with ABS system & ESS & could be due to leaks or malfunction in the brake & or ABS sys. NOTE; TRY TO RESET THE SYS. BY Just ; 1. Dis-connect the battery negative cable, while the ignition switch in the ON position {Don?t Run the engine}. 2. keep it Dis-connect for at least 15 minutes { some experts said 13 hours """ Overnight""" }. 3. Re-connect the battery negative cable, put the ignition switch in the OFF position {Don?t Run the engine}. Then NOW run your engine & see if it disappears. Try it, & PLZ; let me know if I add any benefits to you. I hope I add some thing valuable to you. Regards; MAR; soer2@yahoo.com
Nov 09, 2009 | 1997 Cadillac DeVille
Cobra 25LTD Classic internal neg. wire burnt when I hooked up.
COBRA RADIOS HAVE A DIODE THAT WILL BLOW IF HOOKED UP BACKWARDS, THIS IS A BLACK DIODE WITH A SILVER RING ON ONE END OF IT, YOU MAY HAVE TO TAKE IT TO A CB REPAIR SHOP AND HAVE IT REPLACED, HOPEFULLY YOU DID NOT USE OVER A 5 AMP FUSE
Apr 01, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
Car amp re conecting the the battery
Hook up the battery, (the negative post) and then put the fuse in. This is the best choice because if you put in the fuse and then put the negative post back in and the wires slip when putting in the negative post, the fuse might blow due to the sparks. You will then need to get another fuse, which also mean sending more money.
Dec 04, 2007 | Scosche Industries EFX Amplifier Wiring...
Smoking Amp/Fuse Blowing
Sounds like you may have a shorted switching Transistor in the switch mode power supply causing a short to ground. If you are technical enough. Remove power remove cover and do a continuity test on the transistors on the heatsink. non of them should read zero resistance between the three legs. in all connection configuration you use to hook up your meter. If one or Two or even all of them do you must replace with proper part.
Aug 02, 2006 | Legacy LA838 Car Audio Amplifier
Koiiler 9696-C Car Audio Amplifier Logo
141 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
