Question about Saws
Have a small 10" delta shopmaster table saw on stand. When I am cutting hard wood it will cut off. It will restart with the reset button, however when I resume cutting it will cut off under pressure from cutting the hard wood. Any solutions?
    President:
  • 1,996 Answers
Make sure you're using a sharp blade, and try not to feed to fast for the motor to keep up. Make sure the belts are adjusted properly, ie not slipping.
Try not to use too long or light guage an extension cord to plug into, and make sure the power source where you are plugged in has enough amperage to run your motor without starving it for power.
Otherwise, it could just be a limitation of the motor and the hp of that saw. You'll have to be patient and feed slowly, or upgrade to a heavier duty saw.
What you're describing is undoubtedly the bane of many a weekend woodworker, but the alternative doesn't always come cheap.
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 16, 2009
Cutting 3/4 plywood with craftsan table saw. Motor stopped ???
either overheated the motor and there is a reset at the back--it's a button make sure your out of your wood and fingers away from blade, push it in, see if it restarts, could be a bad extension cord ,connection at the plug ins or you blew a fuse. 3/4 kinda tough
also blade might be dull.heated motor and shut it down.
Oct 31, 2010 | Craftsman 10" Table Saw
Why does the saw cut at an angle?
The table is not perpendicular to the blade travel. Use a small level to make sure the machine is vertical , then set the table. Make sure the blade control guide is working.
Jun 22, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
What is the best use for a 9'' band saw
cutting irregularly shaped wood, plastic, ect...
Jun 12, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
Blade does not make straight cut and turns.
it may be the blade is worn out and has lost its edge on one side or it could be its too lose, on the other hand if your pushing the wood through to fast not letting the blade cut it first it wont cut straight
Mar 27, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Cannot find manual and need to do mitre cuts
for what brand and model number?? Let me know and I will try and help
Dec 28, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Nov 27, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Problems with my band saw bs100
Look for any gouges in the metal surface that have metal projecting above the milled surface. Also, file or grind away any sharp edges along the miter gauge track. If the cut surface is very irregular, the blade may have overly coarse teeth, or the blade guide rollers may not be holding the blade firmly allowing the blade to wander while cutting. Hope this helps.
Jun 27, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta shopmaster saw blade stuck down and won't go back up
sounds silly, but on the right side there is a blue knob.Push down on the saw handle and pull out the blue knob. That should release the saw arm.
Oct 08, 2008 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Saws Logo
101 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
