Question about Dell Latitude D600 Notebook
S video from dvd to tv..no picture
Im using...tryin to use..an svideo connection from my dvd player to tv...the picture flashes on and off the screen and sorta shifts up and down like tvs used to when the channel wasnt turned in properly...is there any way to get a proper picture on my tv?
  • itsallabo177 May 24, 2009
    i've got them both set of the same thing....but still no good
  • 249 Answers
Check your dvd player if it is using the same format as your television. Some locations would use ntsc and others pal secam. If you also have options for changing these to make them compatible with each other do so.
Posted on May 23, 2009
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Help!! Would like to use my ks3102 as a dvd only. How can I do this? Where do I put the plugs in the tv and the dvd? I get a great picture, but no sound. Thanks - I appreciate any help[. Joe in PA.
As far as video connections you can use either one of these connections
As far as audio, you can use the 2 RCA outputs (left - right) marked with the number 4 at the following diagram
Connect these 2 RCA outputs either at the tv's audio in (in case there is one) or use a scart to RCA (with SVideo connector) adaptor (you can ask for this at your local tech store). Use this adaptor at the scart port of the tv and connect at the adaprtor's RCA the RCA audio outputs and the SVideo at the SVideo (number 8) of the DVD player.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 07, 2010 | Koss KS3102 System
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Proscan Svideo Input
Try Googling (proscan)(PS27115)(manual) without parens.
Jul 15, 2017 | Proscan PS27115 27" TV
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Dell Latitude D600 Notebook Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
