Fills with water then stops
The washer fills up with water then stops. You lift the lid then slam it closed and it starts up again.
  • 245 Answers
It sounds like the lid switch is going out if you lift the top of the washer you will see it in there this is a safety feature for homes with small children if your kids are all grown and gone you can connect the two wires going to that switch to bypass it otherwise any appliance parts store will have these switches in stock they are usually around $15
Posted on May 15, 2009
Washer fills with water and then stops
Most washers will fill with the lid open.
Then, the lid has to be closed for it to start agitating.
This is sensed by a switch for the lid.
The lid safety switch is where I'd start to look at.
Oct 05, 2013 | LG Kirkland
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Kenmore 70 series
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number (located around the tub opening under the lid) and look under the "Top and Cabinet" heading. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer just stopped
This is a typical symptom of a defective or loose lid switch. If you open and close the washer lid, you should hear a clicking noise as the lid switch activates. The lid switch is usually located on the right-hand side under the washer casing rim. It is activated through a small slot, by a plastic piece on the lid called a lid strike. There are two mounting screws adjacent to the slot that hold the lid switch in place. Sometimes the screws come loose, or the lid strike breaks off, causing the switch not to activate. Or..the switch simply fails over periodic use. This results in the symptoms you describe. The washer fills, but fails to spin or drain. This is a simple repair that you can accomplish yourself. For step-by-step instructions, please refer to the following link:
If you require assistance in locating replacment parts and/or have further questions, please post back with your complete model number (located aorund the tub rim), along with your comments. That way I can assure the accuracy of any part numbers.
NOTE: Use care not to slam the washer lid. This can also cause premature failure of the lid switch components.
Jun 16, 2008 | Washing Machines
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
