Question about Mitsubishi WT-46805 46" Rear Projection Television
Wt 46805 wont start up
Tv wont power up green light comes on and clicks then goes off the fuse by the plug is good. tv is 7years old and has worked great since 2000. what should i do
  • 1 more comment
  • Tonedef Dec 09, 2007
    Same thing happened to me this morning. Won't power up. Clicks on, then clicks off. Know it can;t be something big, hoping someone that's worked on this before knows the fix vs trying to debug. Any help would be appreciated. Thanks.
  • drussell Jan 05, 2008
    Same problem here.....Tv clicks on and then off again...this is the third different tv ive had this happen to and second different brand. Can someone please help with the cause and solution????
  • DTECH1521 Feb 14, 2008
    I have a similar issue where I power the TV on and I hear a click but no LED. It is addressing to the Dish Network remote and as I power it up I hear the click but no video or audio or LED indicator... Any suggestions?
  • 927 Answers
Good Day, you'll;
Try the following:
NO POWER. NO RELAY CLICK 1. CHECK FOR 5 VDC AT PIN 9 OF IC700 (AC-OFF) IF MISSING CHECK PC901 PART # 268P058020, ON THE POWER PCB. NO POWER. RELAY CLICKS 1. CHECK Q501 (261P071010), Q502 (260P561020) AND Q503 (260P788010). IF ANY OF THESE TRANSISTORS ARE SHORTED OR LEAKY REPLACE IT INSURE THE FOLLOWING CIRCUIT CHANGE HAS BEEN DONE. REMOVE J58 FROM THE PCB-MAIN. USING AN INSULATED JUMPER WIRE, SOLDER A 22 OHM 1/4W RESISTOR BETWEEN PIN 4 OF THE RELAY K9A30 AND THE J58 HOLE NEXT TO PIN 1 OF CONNECTOR DQ. DRESS AND INSULATE THE JUMPER AND RESISTOR TO PROTECT AGAINST SHORT CIRCUITS. INSTALL A .01 UF 50V CERAMIC CAPACITOR BETWEEN THE COLLECTOR OF Q510 AND THE GROUND LEAD OF R502. CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010.
Good Luck, big IRISH.
Posted on Jul 25, 2008
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
TV will not turn On
Call a good TV Tech and have him check for vented capacitors in the DM module or blown pico fuses on the -24 and the +24 volt lines.If fuses are blown,it indicates the convergence amp IC's are bad.The fuses solder into the board.
Jul 28, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Won't turn on.
hi,
try unplugging it and thn plug it back if the light comes for 3-5 sec. and goes off thn you will hear another click noise when it goes off. you never get a picture or sound.If im right thn there are several circuits in the tv that might cause this. the most common are the power supply and the convergence circuits. a cost of a repair for either will range around $400.00. this is a great model and well worth a repair.
good luck:)
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WS-55513 55" Rear Projection...
No power up on Polaroid Tv Model TLA-01511C
When your VGA goes down, try unplugging your tv, then starting it up again. It works for me
Oct 05, 2007 | Televison & Video
Tv has power but wont turn on, no sound and no lights come on
Ihave the same problem with mine. Because it is 11-years old they have no parts to fix it .It is a pitty !! Sorry !!
Jan 20, 2007 | Mitsubishi VS-60607 TV
TV won't power up and blows the fuse
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Sep 11, 2006 | RCA F35670MB 35" TV
Mitsubishi WT-46805 46" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
