Question about Hoshizaki F-1001M Flake Ice Maker
Hoshizaki kml 600 mwh works but no ice no water to wash?
    Problem Solver:
  • 16 Answers
Pleas call out tech. support line 800-233-1940
Posted on Jun 19, 2009
Kml 250mah
some over flowing is ok as long as it does not go into the ice bin. if it is, the drain in the res is restricted some how, or the pump is not pumping the water out. start with that and let me know
May 22, 2014 | Hoshizaki Kitchen Appliances - Others
Hoshizaki Ice Maker KML-250MAH trips after water supply cycle ends
What is the voltage and the amperage of the breaker? Have you taken an amp reading of your ice maker and compaired to the electrical data information found on the ice makers dataplate? How many other electrical appliances are running on that same circuit? I will be here to help should you have questions and or respond, Thanks Sea Breeze
Apr 21, 2013 | Refrigerators
Kml 600 mah manual
go to http://www.hoshizakiamerica.com/. Look for your manual by clicking on "Support" and then fill in the model of your unit and then click "get manual". and you are there.
Feb 17, 2013 | Hoshizaki KML-600M Low-Profile Crescent...
Why does my KML-600MAH only make water not ice?
Check to see how long it stays in the freeze cycle. normally it takes a least 20 minutes to make a batch. If less than that, you are probably loosing water causing an early harvest and almost no ice.
Jan 12, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker KML-450MAH main control switch
What is your question about the switch? not very clear as to what you are asking.
Jul 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KML-450MAH ice maker wont start after clean up
If you did a cleaning cycle and used the bypass valve to clean between the evap plates, look for the micro switch on the bypass valve to be bad. It is a small switch attached to the by pass and keeps the compressor off during the cleaning process. I'd start there.
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
I have hoshizaki kml 450 mah and i need water pump for it can you give me the part number . old onr is burnt out
I can get that pump. Look us up on the repair directory under refrigerators zip code 60060
Northeast Cooling LLC :)
Oct 01, 2009 | Hoshizaki KML-451M Low-Profile Crescent...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Hoshizaki F-1001M Flake Ice Maker Logo
152 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
