Question about Epson RX620 All-In-One InkJet Photo Printer
Screen in copy mode
Copies; works ok
reduce/enlarge; will not adjust
zoom in/out; will not adjust
paper type; works ok
quality; works ok
  • overduebill Oct 15, 2007
    unit purchased 7/20/06at costco
  • Epson Master
  • 691 Answers
Not to sound patronising but review the user manual to ensure you are doing everything just the way it should be. If this makes no difference to the machine, you could have one of a couple of problems.
First could be the button panel or connecting ribbon has gone faulty.
Second could be that the main board has gone faulty.
The first it fairly cheap and easy to fix, the latter makes the machine uneconomical to fix. Maybe you could just live with it or drive the unit to the recycling center!
Posted on Oct 18, 2007
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
How to reduce the size of a color copy?
You will want to press the MENU button on your printer until the Change Copy Settings item appears. You will then scroll through that menu using the left and right arrows on your menu panel until you see the ENLARGE/REDUCE menu choice. This will give you 3 choices to enlarge or reduce your copy. There are Preset Ratio, ZOOM, or Fit To Page.
Preset Ratio has 2 different sizes you can choose.
Zoom allows you to choose from 25% to 400%.
Fit To Page will automatically scan your image and then fir it to the size of page you have chosen to load into your printer.
If you haven't already done so you can go to the following webpage:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Choose the MP210 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000), the actual link is called "mp210sosmwin110us.exe". Clicking on that link will allow you to download the file to your desktop. Then double-click the icon and your manual will automatically unpack and install itself. You will then see an icon on your desktop called MP210 series On-screen Manual. Double-click this to load the actual manual. Then choose User Guide. When the User Guide loads choose Changing the Copy Settings under the Copying heading on the left hand side. You can then see a detailed description of the information I gave you in this answer.
This should let you do your adjustment but if not please let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 15, 2011 | Canon PIXMA MP210 InkJet Printer
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Enlarging copies
To enlarge when using the copy function on the machine, you simply do  the following:
  • Press the Copy button to activate copy mode
  • Choose "Enlarge/Reduce"
  • Press the left or right arrow key until you reach "Custom (25-400%)"
  • Press OK
  • Type in the % you want it enlarged, press OK.
  • Start copying away with Color/Mono Start.
Jun 03, 2009 | Brother MFC 490cw Color Inkjet...
How to reduce the size of the print when copying on canonmx700
press enlarge/reduce button on front panel,
press the right or left direction button on the OK pad, until Zoom appears, press the down button, set the factor by presssing the up and down direction button, press OK to set.
To copy press Start (Black/Color) on front panel.
Same process to reset to the magnification.
Apr 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Reducing/enlarging on Canon MP 160
The only option I see that comes close to this is the "fit to page" option described on page 35 in the manual. Apparently, it detects the size of the original and enlarges it to fit on the paper size selected. Otherwise, I see no options for enlarging or reducing while copying.
May 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson RX620 All-In-One InkJet Photo Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
