Question about Lands Phones
Keypad on 2g iphone stopped working contacts ok but nothing else
SOURCE: Iphone unlocked problems
I am having same problem as well. When I touch the "Phone" Icon it will get to Phone Numeric screen but non of the key is function. I am having IPhone 2G and Firmware 2.1. Please help to provide solution.
Regards
Ben
Posted on Nov 21, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
  • 18 Answers
SOURCE: iphone 2g,home button does not working.
Go to http://www.pdasmart.com for your iphone solutions. They work on pretty much everything. They do not charge anything to look at it.
Posted on May 25, 2009
SOURCE: CANT IMPORT SIM CONTACTS AFTER IPHONE 3.0 SOFTWARE UPDATE
The problem is, for whatever reason, the new iPhone firmware does not allow special characters to be imported onto the new phone.
So the only solution is to:
Get a different phone.
Put your SIM card into that phone.
Access your phone book from said phone.
Delete any contact using characters other that A-Z. This includes !@#$%^&*() And the like.
Once deleted just pop your SIM card back into your iPhone and import. It should now work.
Posted on Oct 10, 2009
  • 56 Answers
SOURCE: i have a iphone 2g the lcd is ok but the touchpad
replace the screen. You can one a amazon.com
Posted on Jul 09, 2010
Can't activate iphone 2G
Hi, is the sim card your using a 3G and not 2G, this will stop it activating. Have you tried doing a full reset of the phone in SETTINGS> GENERAL> and then at the very bottom you see RESET choose RESET ALL SETTINGS, Make sure your contacts are backed up 1st... Let me know.. Mark
May 04, 2010 | Apple iPhone (16 GB) Smartphone
My iphone 2g network ok but calling faild
my iphone 2g network ok but calling failde(tata docomo ok)
Sep 07, 2009 | Apple iPhone Smartphone
No signal
Sir if your are using a 3G iphone with AT&T as a carrier than please contact them for support
If your iphone is jailbreaked ie it is unlocked and you use it with some other carrier or in another country then update your iphone to firmware 3.0 using this step by step detailed guide
for iphone 2g using windows
for iphone 3g using windows
for iphone 2g using mac
for iphone 3g using mac
for further information about jailbreaking please contact me
NOTE I DONT RECOMEND YOU TO JAILBREAK IT... its illegal
Thanx and i hope this helps
PLease rate this solution THanx
Jul 17, 2009 | Apple iPhone Smartphone
Bottom row of my keypad doesn't work
You have to get it changed
2G iPhone - FULL LCD with Touch Pad !. 3G iPhone - Only Touch Pad !
Best Regards
Jun 24, 2009 | Apple iPhone Smartphone
IPhone keypad not working: touchpad works fine otherwise
did you get your phone working? reboot by press and hold the sleep and home buttons until the apple appears.
Jun 05, 2009 | Apple iPhone Smartphone
Iphone 2g unlocked,cannot connect w/ edge. wifi is working
Jailbreaking your iPhone to 2.2 is going to mess up your phone. I've got a jailbroken 2.2 iPod Touch and it's ok - a friend of mine also tried to jailbreak his iPhone to 2.2 and lost connections as well.
Downgrade back to 2.1 and you should be ok.
Dec 02, 2008 | Apple iPhone Smartphone
IPhone dialing keypad problem, 2g , 2.2 firmware
I just found the answer on another website. Go onto installer or cydia and uninstall Mobile Enhancer. Restart your phone and it will work. Thank god!
Nov 28, 2008 | Apple iPhone Smartphone
i just purchased an unlocked i phone 1st gen and it was working fine with my tmobile carrier but all of a sudden i synced it with i tunes and now it wont let me make calls
Oct 11, 2008 | Apple iPhone Smartphone
Lands Phones Logo
133 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
