Here are some possible causes and solutions:
Belt Issues: If the drive belt is broken or loose, the tines won't turn. Check the belt tension and replace the belt if necessary .
Idler Assembly: If the idler assembly is not properly tensioning the drive belt, the tines won't turn. Adjust the idler assembly or replace it if necessary .
Engagement Cable: If the engagement cable is loose or not tensioned properly, it may need to be tightened or replaced altogether .
Transmission Issues: If there is an issue with the transmission, such as a broken gear, the tines won't turn. Stop using the machine immediately and inspect the transmission .
Since you mentioned that your tiller tines were turning fast after replacing the carburetor and then stopped turning after connecting the throttle cable, it's possible that there is an issue with the engagement cable. You may want to check if it's properly tensioned and connected to ensure that it's not causing any issues
How To Fix Tines That Will Not Move - Tiller Repair
engine running well but after pressing lock out button & pulling trigger there is no action of tines
I have the same problem on my front time tiller the belt broke and no answer of how to put new one on
