Question about Acer Aspire L100 PC Desktop
Acer L100 comp wont start past the windows loading screen
I was starting my computer as normal the other day and it said that it had a disk check to do so i let it. then after it getting to the final process of the disk check i got fed up with the slow speed at which it was finishing so i just simply turned it off, and ever since when I turn it on it takes me to the "sorry windows suffered an error" screen and gives me the option of starting the comp in safe mode, safe mode with networking, safe mode with command prompt, last known good config., and starting windows normally. Now i have tried all 5 of windows so called solutions and all of them do the exact same thing, they bring me to the windows loading screen and then after it loads it reboots and starts all of this crap over again. any help will be much appreciated.
Shutdown possibly damaged the boot sector on hard drive, get service agent to ghost your files onto another disk, and repair boot sector and then put your files back
Posted on Nov 01, 2007
  • 452 Answers
Open My Computer, and then select the local disk you want to check.
On the File menu, click Properties.
On the Tools tab, under Error-checking, click Check Now.
Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
Posted on Oct 17, 2007
  • 110 Answers
If I were you I would reformat your PC. In short words reformatting you Delete everything from the pc, the reinstall the OS(Operating System). Once the process is done, your PC is alot faster, and fresh. What happens to most people's PC it gets bogged down, and you go along time without cleaning it it will crash, just like a car.
There are hidden folders within the OS such as the prefetch where files are kept to help you boot problems faster, but the prefetch gets bigger each day, and isn't really needed.
To clean the prefetch you would go to Start>Run>type "prefetch" without quotes, once it opens the folder delete ALL files in it, a shortcut is to click any fil inside the prefetch, and press "ctrl+A" that will select all the files and now simply press Delete, and confirm Yes.
Something else to help maximize your system is to do a "disk clean up" access that by going to start>all programs>accessories>system tools
I hope this helped you maintain a better system in the future, if I were you I would go ahead and do the reformat then use the tips I just gave you to keep your system in shape.
Also another top make sure you keep your system clean of threats,(malware,spyware,adware,etc...) I would recommend Norton or Mcfee, I go with and, another one I like is its up to you which you choose.
Good Luck!
Posted on Oct 16, 2007
I have an acer one 8.9" laptop. I down loaded a torrent that stopped and started a few times and said I had a bad hard disk. Now I cant get past the acer start up screen. Ive with the external disk drive...
Try re-starting in safe mode, press F8 as its booting, assuming all goes well choose safe mode, this loads a windows shell. Using Accessories - System tools - System restore - Restore to a point prior to your problemsn.
Sep 21, 2010 | Acer Computers & Internet
I have an Acer Aspire 110 netbook and all of a sudden it won't get past the disk check stage when I turn it on. First it says that Windows did not start properly, so I choose to start Windows normally from...
This may be due to faulty/corrupt system files. If you have windows installation disk with you, boot from it. Do a start up repair using the tool in it. This will fix the startup problem. If you want full guidance, comment me which windows you are using.
Feb 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
My acer 1 when started up keeps going to a checking file system screen and just keeps doing a disk check
For that when you power up the computer press F8 key then enter in "Safe mode"
Then go to start menu->run
Type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.
After completion of disk checking it load windows but if still not load windows then you need recovery disk or windows disk then boot computer with it then repair old windows.
Nov 15, 2009 | Acer Aspire One PC Notebook
My Acer Aspire won't boot up past the Window's Loading bar
Log in to safe mode by pressing F8 during startup, if you see windows loading you have missed your window to push the F8 key. When the options menu comes up choose safe mode.
While in safe mode if it loads, click Start > Computer (My Computer) > right click on your ‘C’ drive and click properties > click the ‘tools’ tab > click the ‘Check Now’ button under ‘Error-checking’ > make sure the options ‘Automatically fix…’; and ‘Scan for and attempt recovery of bad sectors’ is checked. A dialogue box will come up stating “windows cannot check the disk”, just click the ‘Schedule disk check’ button and restart your computer. When the computer starts up a check disk will start, let it run. you might want to go do something as the check disk may take up to and sometimes longer than an hour.
Let me know if that helped, and please rate me after, thank you.
Jun 26, 2009 | Acer Computers & Internet
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Cant get into windows at all
You might try turning your floppy drive off if you have one.
Nov 25, 2008 | Acer Aspire T120 PC Desktop
Acer Aspire L100 PC Desktop Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
