Question about Radio Shack Pro-94 Scanner
My Radioshack Pro-64 scanner was left in the rain and wont turn on now. I took the cover off to see the internal motherboard; i guess you could call it that, and it is very clean, with very minimal trace amounts of rust or corrosion. any suggestions???
    President:
  • 2,761 Answers
Water and electronics just don't mix, so there's no telling how much damage was done. If you haven't already done so, remove the batteries, wipe the internal contacts with a dry cloth to remove any rust/corrosion, then try powering up with fresh batteries. If it doesn't power up after that, you can consider taking it to a local Radio Shack or repair shop for an estimate, but keep in mind that you can buy an exact replacement for about $70.
Posted on Dec 24, 2009
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Radioshack pro 67 need to factory reset
I'm not all that familiar with the unit, but found these instructions for you at the link below. REMEMBER: you are going to erase EVERYTHING when you do this. Quoting manual:
RESETTING THE SCANNER If the scanner's display locks up or does not work properly after you connect power, you might need to reset the scanner. Caution: This procedure clears all the information you have programmed into the scanner. Before you reset the scanner, try turning it off and on to see if it begins working properly. 1. Turn off the scanner. 2. While you hold down the 2 and 9 keys, turn on the scanner." (End of quote)
Click on the link below and choose "Troubleshooting" from the menu.
RadioShack PRO 67 Scanner 200 0512
Jul 15, 2014 | Radio Communications
Radio shack pro 96 software update
Hi John,
Your Pro-96 is the Radioshack equivelent of the Uniden 93xlt.
If Radioshack website does not have the software available for download, you could try the Uniden web site and download the software for their 93xlt, as it's the identical radio with different Make/Model, but made in Japan in the same factory.
My guess is Radioshack would have the software to download, as these radios are still current models.
I hope this helps you with your query.
Cheers,
Peter
Feb 07, 2013 | Radio Shack Pro-95 Handheld Scanner
Can i buy a new battery cover fo my pro-95 scanner?
Check with your local Radio Shack store, or send a query through RadioShack.com. If the part is available they will be the only source -- unless you can find a parts unit on eBay.
Bill B.
Listening in since the 60's
Apr 21, 2011 | Radio Shack Pro-95 Handheld Scanner
Need programmer codes for a pro-64 hyperscan scanner
Programmer codes? If it's the operating frequencies for agencies in your area that you're looking for, you can find them and a lot of other useful scanning information at:
www.RadioReference.com
Need the operating manual for your scanner? You can download and print it here:
http://support.radioshack.com/support_electronics/36549.htm
Bill B
Jun 08, 2010 | Radio Communications
I unplugged it to take to another room and now it wont turn on. is there a reset button
Sorry but no there is no reset button on any of those radioshack models try going back to the original spot that you had it connected to and see if it works if not then there are 2 thing it could be 1 the power supply went bad second is that when you unpluged it (guessing that you didn't turn off the scanner) that when you unpluged it you sent a surge through the pc board and poped a diode you can send it out to be checked and or repaired by radio shack at any of there locations can handle your needs
Dec 25, 2009 | Radio Shack Pro-2018 Scanner
Have a pro 97 scanner and try couple of computes to program it
You need police scanner programming software and a cable before your computer will talk to your scanner.
Do a google or yahoo search for police scanner software. About $25 and a cable from radioshack for about the same. The disk that comes with the cable will only let your computer recognize the cable not program the scanner.
Good luck. Waste of money in my opinion but it may be easier then manual programming the radio.
Jul 24, 2009 | Radio Shack Pro-97 Handheld Scanner
Pro-2096 Digital trunking mobile/ base scanner
This is happing to most of the units and radioshack wont admit it.
Apr 18, 2008 | Radio Shack Pro-2096 Base Scanner
Pro-97 20-527 scanner
You can download the manual from the link below: http://support.radioshack.com/manuals/ome20-527.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-94 Scanner Logo
227 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
