Question about Hotpoint Aquarius WMA42 Front Load Washer
To fast hi my washing machine seems to be going to fast
  • 56 Answers
If there is a taco on the end of the motor which detects speed it could be loose or broken of,(connections at motor plug for this could be broken also thus no feedback to motor module)the taco is 40mm dia by 10mm thick which takes its dc output from a magnet revolving on the motor,the motor control module have been known also to cause this fault-hope this helps
Posted on May 15, 2009
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
WASHER NOT SPINNING ALL THE WAY OUT CLOTHES STILL VERY DAMP DOESNT SEEM LIKE GOING INTO A GOOD GEAR ITS SPIING BUT NOT REAL FAST
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 23, 2011 | Whirlpool LSR5132PQ Top Load Washer
Washing machine seems to be washing ok but when it comes to the final rinse and spin the soapy water is pouring out of the soap dispenser on the front
this is happening because the machine is not draining the water away fast enough when going into the spin cycle. clean out the filter under the machine, this will solve your problem.
pallesappliancerepairs.com
Feb 04, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Malber WD1000 won't hi-speed spin
check if the drum assembly is loose, but it seems like one of the mounting arms or shocks broke.
Jul 10, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Washing Machine Top Load
He's right, need a brand and approximate age. Could be a tub bearing. Some brands are known for this problem.
Oct 07, 2007 | Washing Machines
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
Machine banging when in fast spin
or the three legged spider that attaches to the drum. its made of cheap metal and one or more legs can crack or break letting the drum loose - seems like bearing but isn't! cost about £40
Sep 28, 2006 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
