Question about HP LaserJet 2420 Printer
49.4C02 Service Error
Our printer HP LaserJet 2420n was working great for nearly a year.  Then today, between print jobs, it went to this error (see subject) on the screen.  I called HP tech support since its still under warranty and spoke to someone NOT helpful.  Basically she said we had to update the firmware.  She faxed me cheat sheet on how to update this.  However, it claimed that when I put in the IP address of the printer into internet explorer, I would see a folder I would then drag a copy of an .RFU file (I had downloaded this per her instructions) into port1.  There was only a link to a port 1 but no folder.  Anyway, when I dragged this RFU file to this link, it would switch the window to a bunch of computer code.  Then she would have me turn off the printer and turn it back on.  It would look all normal, and say ready.  THEN, it would say "Processing job" and the data light would flash for about 30 seconds, then nothing happened and that was it.  It would give me that same Service error again.  She then had me pull out the printer's memory and put it back in and turn the printer back on.  Still didn't work.  And now when I power up the printer, it has a blank display screen (which means all my settings are lost!).  That's when she decided I needed the printer repaired and my options were 1. pay $69 to get a new one shipped to me and return this bad one or  2. Work with a local HP authorized repairman-FREE  or   3. Have them ship me a prepaid box, then send it back, and then wait for HP to fix it and eventually return it.  FREE  I have chosen option 2 and the repairman is coming tomorrow.  However, I may need to wait a week for parts! Any help to fix this sooner would be great as I need to get this back up and running...its our networked workhorse printer for my entire 6 person office.
  • trinityb Oct 16, 2007
    Thanks for trying!  That is what she was having me do when I called HP tech support, but that didn't seem to work per her instructions and frankly made things worse.  Hopefully the technician today can fix it.
  • Anonymous Sep 03, 2008
    received
The 49.4C02 error usually follows a paper jam. When the user closes a door after clearing the jammed media from one area of the printer, the control panel immediately posts a 49.4C02 error. Often, the customer will then power cycle the printer and it will hang at Checking Printer. For the 49 error to occur, additional media must still be stuck in the paper path.
Firmware version 5.005.3 contains a fix that allows the printer to recover and notify the customer of the location of the additional jammed media in the paper path. Customers who experience this issue should update to the newer firmware
Posted on Oct 15, 2007
I use a mac. I checked for jams. There were none. I powered off my printer. Turned it back on. Then went to my System Preferences and opened the print queue of my Printer. My printer was Paused. Deleted the files in my queue. Clicked Resume, then sent a new document to the printer and it printed just fine. I did this a few times with no more problems. I hope it's this simple for everyone else.
Posted on Mar 27, 2009
FIRMWARE ERROR. REPLACE THE FORMATTER IF UPDATE CANNOT BE COMPLETED.
Posted on Sep 13, 2011
Porbably a font causing this. try change the printers resolution to 300 dpi. Make sure you clear any pending print jobs first to avoid the error when you cycle the power. the set 300 dpi in the printer's print quality settings.
Posted on Apr 16, 2010
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
  • 17 Answers
SOURCE: problem with our printer 5200tn
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
vendor for assistance.
Posted on Dec 18, 2008
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
seeker5211
  • 1089 Answers
SOURCE: service error 49. 4c02
Go to hp.com download and install the latest firmware.
Follow the directions.
Posted on Aug 22, 2010
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP LaserJet 1220: all lights are on
Hi
The complete list of the light patterns, causes and what should you do, are there on this link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=29789&prodTypeId=18972&prodSeriesId=29789&objectID=bpl10633
it looks like this
Type of error Light pattern Recommended action No power - The printer is not connected to a power supply. c00031238.jpg Plug the printer into a power supply.
If the printer lights do not turn on, contact HP. Ready - The printer is ready to print. c00031239.jpg No action is necessary.
To print a configuration/self-test page, press and release the GObutton on the printer control panel. Processing - The printer is receiving or processing data. c00031240.jpg Wait for the job to print.
Oct 20, 2009 | HP LaserJet 1220 Printer
Is HP Laser Jet 2420n
Duplex on this printer is manual, that means that you will have to re-insert the paper by yourself.
This if you have the 2420n, the 2420dn instead is the duplex model.
Here specifications, look where it says duplex, 2420n had only manual duplex (the printer wait for you to re-insert page).
Feb 17, 2009 | HP LaserJet 2420n Printer
Support
49.XXXX
PRINTER ERROR
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
Dec 10, 2008 | HP LaserJet 2420dn Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
occurred that caused the
to abort operation. This type
parallel cables, poorconnections,
or home-grown
programs. On rare
fault, which is usually
Error.
clear the print job from
the printer memory.
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP LaserJet 2420 Printer Logo
7,082 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
