How to create a dynamic graph in php - Computers & Internet
You can try tool from here <a rel='nofollow' href="http://origramy.com/phpdemo/">http://origramy.com/phpdemo</a>/ it's a flash component for building diagrams and graphs with ready php solution.
Posted on May 22, 2009
    Sergeant:
  • 186 Answers
Try this links and download source code from there :
http://www.wellho.net/mouth/1104_Drawing-dynamic-graphs-in-PHP.html
or
http://www.lestercat.net/dev/svg/SVG_graph/
or
http://code.google.com/apis/chart/
Posted on May 15, 2009
Only graph one function at a time
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T), Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  4. Calculator displays Done
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognize that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays Inequal RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Mar 18, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator doesnt graph two equation on the graph
  3. Press [ENTER].
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
  1. Press [Apps]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Mar 17, 2010 | Texas Instruments TI-84 Plus Silver...
When I put an equation into y=, there are arrows to the left, I don't know why
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T0, Y1=f(T))
  3. Press [ENTER].
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionality from the native OS and you can only draw a single graph.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionality will revert to the native OS
Mar 17, 2010 | Texas Instruments TI-84 Plus Calculator
Graphing is messed up
You may have activated the dynamic graphing by running the Transfrm Application. If so, you must unload it from memory (this will not delete it from calculator)
  1. Press the Apps key.
  2. Use UpArrow (yes UpArrow) to scroll to the bottom of the list of applications.
  3. Point to Transfm and press ENTER.
  4. In new screen that displays, select the option that uninstalls Transfm.
  5. Do your graphs in the usual (native) environment.
Mar 02, 2010 | Texas Instruments TI-84 Plus Silver...
I cant graph more than one equation at a time, it only allows me to graph one Y value at a time.
  3. Press [ENTER].
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. You recognoze that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
  1. Press [Apps]
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Feb 17, 2010 | Texas Instruments TI-84 Plus Calculator
Won't graph two functions
A) IF YOU GET AN ERROR MESSAGE,
it might be worthwhile to let us know its contents. If you do get a message ( INVALID DIM) you should turn the statistical plots OFF.
  3. Press [ENTER].
B) IF YOU DO NOT GET AN ERROR MESSAGE
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. To Uninstall it, do as for the Transfm and select the option that will unload it from memory.
Jan 25, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 won't graph multiple lines
  3. Press [ENTER].
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
When I type a linear equation into my TI 84-plus graphing calculator under the Y= sign and need to view multiple equations it will only show me one and won't allow me to select more than one at a time. The...
You can skip the next paragraph if you want
Press the [Apps] key. Scroll down or up to reach the Transfm application. Select it and press [ENTER]. If that application was running you will see a new screen that tells you
Transfrm App
  1. Uninstall
  2. Continue
Press1:Uninstall.
Another potential culprit is the Inequalz App. To uninstall it, do as for the Transfm and select the option that will unload it from memory.
Jan 14, 2010 | Texas Instruments TI-84 Plus Calculator
Plotting graphs
usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
Press the [Apps] key. Scroll down or up to reach the Transfm application. Select it and press [ENTER]. If that application was running you will see a new screen that tells you some t
Transfrm App
1:Uninstall
2:Continue
Press1:Uninstall.
Jan 09, 2010 | Texas Instruments TI-84 Plus Calculator
I am in need of source code for dynamic line graph in java
sir,
i need the smartmovie key.
device serial number is : 355740023968755 &
key?
Apr 06, 2009 | Microsoft Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
