Question about HP Photosmart C7280 Printer
HP C7280 will not let me use a re-filled cartridge
My C7280 HP printer will not let me use a re-filled ink cartridge. The printer recognizes the cartridge chip, and has noted it was emptied before. Tech support says there is no fix - I have to go buy new catridges. I tried changing the chip with the one on a colour cartridge, but I didn't fool it. There must be a fix to let us re-fill cartridges! Help!
    Problem Solver:
  • 6 Answers
Using an original cartdrige.
Posted on May 15, 2009
MY HP Pavilion computer says that the HP PHotosmart C7280 printer needs new black ink cartridge, but the printer has already recognized the new HP cartridge as genuine and ok'd it. I downloaded all HP...
Take the printer cartridge out of the printer and turn it off. Then turn it back on again and check the status in the computer on the ink available in the cartridge. If the pc does not recognize that there is no cartridge in the printer when it is removed then uninstall the software, disconnect the usb cable from the pc to the printer and go to hp's website to reinstall a newer version of the software www.hp.com.
Oct 21, 2011 | HP Photosmart C7280 Printer
I inserted non-HP cartridges into my C7280 printer and the display says "the ink cartridges appear to be missing or damaged", If I put the original HP cartridges back in, the error message...
Turn off your printer
Open the cover
1 .move the cartridge carrrier manually to the center manually with your hands from left to rgiht ( 5x )
2 .Open the cartridge carrier Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean specially the gold plate .CLean also the area where you return your cartridges also the contacts on the cartridge carrier make sure its clean OK .
Then return it again
You may also do that when your printer is on
1 . Open the cover first wait for the carrier to move to the center
2.thats the time you will remove the cartridge and clean and clean the cartridge carrrier
3.open again the cover reinsert the cartridges
make sure its close properly
Hope it help ..
If still nothing happens probably you have a fake cartridge which is not recognized by the Hp printer Ill be advising you to return it back and asked for a replacement OK
May 28, 2011 | HP Photosmart C7280 Printer
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
I have a HP C7280. When printing the text is very light. Like it has a clog or something. Ran alignment and it says alignment failure. I run the head clean. and it still prints super light.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 04, 2010 | HP Photosmart C7280 Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
Ciss ink won't work on hp c7280
Must use included HP "starter ink" cartridges before the CISS can work. There's a 3-button sequence [OK-Cancel-Black Button] sequence when powering on that will reset the printer and bypass the "starter ink" wall you're hitting
Jun 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
C7280 printer wont recognize newly inserted ink cartridge! HELP
Try cleaning the gold contacts on cartridge with DISTILLED water and cotton bud, allow to dry and reinsert. Make
Apr 15, 2009 | HP Photosmart C7280 Printer
HP Photosmart C7280 Printer Logo
288 people viewed this question
Seeker5211
Seeker5211
