Question about Sony PlayStation Portable (PSP) Console
Buttons Dont Work?!
After i am done using the psp, the previous time, i went to HOME
and realized i cannot move my option to the yes option. I can't navigate at all. I can't press the O or X button as well. Not only that, by pressing the left directional button, the character in my game is the one moving.
In the end then i just off it completely by holding the power button.
As i on my psp today, some support screen appeared. the directional button now were fine hence i moved to the EXIT option there and exited from the screen.
After which all buttons cant work. Only the volume and the brightness buttons can. i try putting it to stand by mode, it hung for a while then off completely. Are there any solutions to my problem?
What does that mean
Posted on Aug 08, 2009
Hi, i just have same problem, i've changed low button bar part. It solved!
hope it will help.
Posted on May 26, 2009
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
I dont know how to put d games in the psp
Hi jay_saske08,
Based on your concern, I suggest trying the following steps:
1. Connect the PSP to your PC with a USB cable.
2. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
3. Use the left-right directional buttons to find"Settings", then the up-down buttons to find "USBConnection" on the PSP.
4. Press the "X" button, your PSP should display"USB Connection".
5. Please wait until your computer tells you that a new USB devicehas been connected, then show you a new generic hard drive, usually E: or F:
6. Click on the drive letter that corresponds to the PSP unit.
7. Now look for ISO folder then copy your desired game (ISO file)into the folder.
8. When you're done copying your desired games, press the"O" button on the PSP to get out of USB connect mode.
9. To play the game, Use the left-right arrows to move to the gamearea, then the up-down arrows to find "Memory Stick". Chose thatfolder by pressing the "X" button again, and you should be able toplay all your favorite game!
Hope it helps,
Thank you for using FixYa,
Sep 28, 2010 | Sony PSP (Piano Black)
I dont know how to install games on the psp
Hi heroahmad,
Hope it helps,
Apr 20, 2010 | Sony PSP (Piano Black)
Psp start button not workin home menu not either
try dismantling your psp and see the inside of it, you said you cleaned the buttons. try to see if the chips inside the psp are sort of dirty and stuff, the access points in wear the buttons touch, if this still doesn't work, just go to a original SONY STORE.
Apr 05, 2010 | Sony PlayStation Portable (PSP) Console
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
CANT CHANGE GAMES AS CIRCLE BUTTON & HOME BUTTON NOT WORKIN!
Use pandora battery and downgrade ur psp into 1.5 firmare, upgrade it slowly ( dun upgrade it up to 3XX directly).
Mar 13, 2009 | Sony PlayStation Portable (PSP) Console
About music
i have placed an answer to your previous premium post, this may work as well as my first suggestion and Marked's.
  1. Connect the PSP to your PC with a USB cable. (about $10: buy a USB cable for your PSP)
  2. Press the "home" button on the PSP (it's a tiny button to the lower left of the screen) then use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
  3. Press the "X" button (you got it, the round button with the "X" on it) and your PSP should display "USB Connection".
  4. In a moment or two your computer should tell you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
  5. Click on the drive letter that corresponds to the PSP unit.
  6. Now create a new folder on that drive and name it "psp".
  7. Within the new "psp" folder create another folder, and name it "music".
  8. Copy your desired mp3 files into the new "music" folder.
  9. When you're done copying your desired music tracks, press the "O" button on the PSP to get out of USB connect mode.
for more information click on the link below.
http://www.askdavetaylor.com/pc_to_sony_psp_how_do_i_download_music.html
hope this helps.
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
The "home" button on my PSP does not work
I have the same problem.. I cant put YES on home and my R button isnt working either.. but I've noticed that if I push down the power button to the HOLD lvl and then put it again to the medium lvl it works like the R button -_-'' ..
Jan 06, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
431 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
