Question about HTC G1
HTC G1 dead, can't power on, factory reset/soft reset not working
My android G1 is dead - doesn't respondto power on. I have put it on charger for a couple of hours without any effect.
I've even tried both soft reset and factory reset without success.
This phone is not used in the US so I can't return it to T-Mobile :(
I'm not sure what the problem is - could be the battery is dead, but I haven't had any issues with it (apart from the ordinary short battery life when data, GPS are on).
As it is now it's a paper weight on my desk, and I'll be a bit hesistant about recommending a phone to anyone, even a power user - and I'm a pretty advanced IT user.
Any help will be much appreciated.
Can I replace the battery with any other HTC battery?
  • 502 Answers
Well try to get your hands on either a second G1 phone or a multimeter to rule out a battery issue. If you take a charged battery from another G1 and it still doesn't turn on you will have a logic board issue. With a multimeter you can measure the battery directly, if the phones doesn't turn on if the voltage is over 3.7V, you'll have a logic board issue as well. Within one year T-Mobile should give you a replacement. If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices that are not meant to be user serviceable.
Posted on May 17, 2009
I have my g1 unlocked here in the Philippines. The person who unlocked it for me used his own google account to make it work. Now I can't use its other features because it needs the password, and I...
Hi dc_anasela,
First off, you need to un-freeze your unit by taking the battery out and then putting it back in. You had the right idea in restoring the factory settings. You may want to try it again. Here is the recommended way of doing it: -Hold the HOME and POWER keys at the same time for about 20 seconds. -Press Alt+L after you see the Warning screen ( Yellow triangle with an Exclamation Point ) -Press Alt+W to do a factory reset. -Press the HOME and BACK keys again for 20 seconds to complete the hard reset.
If the problem still persists, you may need to contact the person who unlocked your phone and get the password from him. I hope it does not come to that. Good luck, I hope everything works out for you.
Jul 16, 2011 | HTC G1
I am having a problem with my g1 screen, it was dead so it shuts down by itself then when i turned it on it has black screen. is there any solutions for this?
Can you take the battery out? wait for 15 seconds and put it back. Check it work or not.
If not, can you do the soft reset? the is the reset button on HTC.
Hope this will help.
May 18, 2011 | HTC G1
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
I tryied the pattern to many times and locked my g1 and the google sign will not work wat do i do?
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored!
From http://www.androidcentral.com/factory-reset-tmobile-g1/
Mar 08, 2011 | T-Mobile G1 Android HTC Google Smartphone...
My G1 or HTC dream won't start up beyond the android logo. I have tried removing the battery and or the sim card.. It still does not start up. I tried hard and soft reset to no avail. After the android...
wipe the phone clean remove the battery and out it back in hold the home & power button at the same time untill black screen pops up press ALT and W to wipe & that should fix the problem
Aug 30, 2010 | HTC G1
My phone is frozzen
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
May 08, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Other than the G1 and Android appearing when my phone powers up, the screen stays blank. any ideas on what may be wrong?
Easy i just figured it out with my g1 with the same problem. The solution is this: Try taking out the battery put it back in. press and hold the power+home butto. a screen will show then press the power and home button agian. It will then give you some choices, choose wipe out your memory to factory settings and it should work after.
Apr 11, 2010 | HTC G1
I just dropped my Android G1 and now it won't turn back on. I took out battery and put back in but nothing. Is there any way to reset this phone?
There is a small hole on the bottom of the g1 where you charge it. Something small like a paper clip or something can fit inside and that will reset the phone to factory settings. Not sure if it will turn it on though...
Dec 10, 2009 | HTC G1
HTC G1 Logo
2,126 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
