Question about Philips Magnavox 27MS343S 27" TV
CAN NOT GET CHANELLS ABOVE 13
MY MAGNAVOX TV ( OLDER 19 INCH MODEL) IS GOOD UNTIL I GO ABOVE CHANELL 13 THEN ALL I GET IS SNOW. WHY?
  • 709 Answers
Hi vince14,
Here is the adobe url for your users manual. I will be looking through it and get back with you momentarily to show you the procedure  for getting your tv to go to cable mode. Thank you very much for this opportunity to assist you.
http://www.p4c.philips.com/na4/2/27ms343s/27ms343s_dfu_aen.pdf
Posted on Oct 16, 2007
  • Greg Stokes
    Greg Stokes Oct 17, 2007
    Hi again Vince14,
    I got your Procedure and menu pictures set and posted for your easy solution to get your TV to see all channels.
    This is what you need to set your TV to to get channels above 13 to work.  Thank you again for this opportunity to help you, Please vote solved.  You only get one chance to vote so please do vote solved after you get your tv seeing channel above 13. I put alot into this and hope to get a solved vote. Thank you very much, Cerfer39
SOURCE:
Magnavox 19 in lcd manual guide
Here is the link to the manual of Magnavox 19MD359B (19 inch LCD TV)
Magnavox 19MD359B
If that is not the model of your TV (there are many models of 19" magnavox TV) please indicate it so I can look it up for you.
You can rate my answer if you appreciate my work for looking for the manual of your TV.
Thanks.
-damneddle
Oct 06, 2011 | Magnavox 19MD359B F7 19 in. HDTV
I get channel until #13 how does i get the other chnnel
TV's of this era have two modes that the tuner can work in. One is the AIR mode and the other is CABLE. In the air mode the tuner picks up only "off air" frequencies,... and up to channel 13 they happen to be the same as cable channels 2 thru 13. If you are using cable you will need to go into your on screen menu and find where to change the tuner from "air" to "cable" to get channels above 13. Older sets had a switch on the front and sometimes the back to select the tuner mode.
Aug 14, 2010 | Curtis CM19033S 19" TV
Sir I need an estimate value on a magnavox tube 19 inch tv. we were robbed and the tv was completely broken. The insurance co. needs a price. can you help me. Thank you for any help.
Depends which country you're in, but in the UK the value of any 19" cathode ray tube tv (the old bulky ones) is effectively zero as it's difficult to even give them away now. As they're classed as hazardous waste they actually cost money to throw away.
For insurance purposes, buying a good used one including shipping is about £70 and that's also what many used tv shops may charge for a refurbished, guaranteed, ex-rental model with delivery included.
If you have a new for old policy then the value is effectively the cost of the cheapest Philips (or brand equivalent) 19" LCD tv including delivery and installation costs.
Aug 02, 2010 | Philips Magnavox 27MS343S 27" TV
1995 Magnavox tv (model TS2560) Horizontal control WACKY
No, it is most certainly not worth fixing. In fact, it is worth nothing - even if it were working great. Probable cause: an obsolete electrical component. Cost: no TV tech will touch it. Sorry. Suck it up and buy yourself a moderately priced TV.
Jul 28, 2017 | Philips Televison & Video
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
ZN110 remote
Magnavox codes 002,009,109,118,309,402,408,502,508,510,807, 917
May 11, 2008 | Zenith ZN110 Remote Control
19 INCH OLDER MOEL
Hello.
You did not say if you were using cable or antenna. If cable, you need to use the remote that came with the TV. Get into the menu and look for channel setup or an equivalent heading. in one of your menu schemes will be a selection fot ant. or cable. Select cable and the other channels will magically apear when you exit the menu option.
Good luck.
Oct 17, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
