Question about Pioneer Televison & Video
One side of my tv heats up on my pioneer pdp4214hd
I have a pioneer model pdp4214hd and I noticed that while watching it the rear right side stay cool but the rear left side is very hot.
    President:
  • 788 Answers
Because this is a Plasma flat panel there are fans in the back of the unit that will keep things cool. It sounds like there may be a fan that is not working on the left side. I know that my plasma runs very warm, around 98 degrees F. The power supply is also on the side that you are talking about. Since the set is still working, I would not suspect any other problems, but, I would not run it very much until the unit is repaired.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
Posted on May 15, 2009
Convergence problem
What model number of Pioneer TV set do you have? There should be a large heat sink or something metal with cooling fins on it where the IC's might be mounted away from you so you will need to look at the other side of the heat sink. Replace those IC's and you will be able or should be able to adjust the set providing you have not tweaked it too much before repairing the problem. Good luck
Feb 11, 2008 | Televison & Video
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Tv wrks for 20 minutes, the the picture and sound shuts down
try cooling down tv with a fan to see if it stays on longer. if so, it's overheating. then to next step. feel for excess heat and look for dark areas on components inside. it may be obvious. if not, you may need to call a pro or replace the set. best buy use to do basic diagnostics for $25, but that was about 7 years ago
Nov 25, 2009 | Pioneer SD-582HD5 58" Rear Projection...
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Remote control dosnt work on this tv
I have the same plasma Pioneer tv. I also tried a replacement remote and no fix. I replaced the infrared receiver module (~$4 from Radio Shack) on the TV, yes it involved taking the tv apart. Voila, now I have two working remotes.
May 12, 2009 | Pioneer Televison & Video
Pioneer plasma pdp4214hd shuts off after being on for about 20 min.
Are you able to turn the TV back on immediately or do you have to wait? If the TV is consistently shutting off around 20 minutes, this may indicate an overheating issue. It is possible that you need to clean the TV out of dust or it may mean your cooling fan is dead or not revving up when the temperature rises. If you are not able to turn the TV back on right after it shuts off, overheating is likely the issue, as you would be forced to wait until it cools down. If you are able to turn it back on, for how long? Does it continue to shut off after another 20 minutes? It is possible that the thermal sensor on the mainboard is defective, or that the software that controls the sensor maybe corrupt. Service or a firmware update may resolve this. You would have to contact the manufacturer.
Oct 17, 2008 | Pioneer Televison & Video
Pink pixels across plasma screen.
I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
Dec 23, 2006 | Pioneer PureVision PDP-503CMX 50 in....
Televison & Video Logo
75 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
