Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
No pic and shuts off
My tv turns on and there is sound but no pic and after about 30 sec it turns off the door to the houseing is warped from the heat of the lamp do you think if I replace the dor it will stay on or is there more of a problem then that thanks
  • 113 Answers
If the housing of the door comes open you will lose the sound and picture almost instantly. Have you replaced your lamp in this tv it sounds like the life on your lamp is coming to an end.
Posted on Feb 04, 2008
Tv shuts self off after 30 sec
It says it is a Mitsubishi WS-65809--can you confirm that?
Mar 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Turn t.v. on, stays on for 30 sec., then shuts off.
While the set is on does the picture and sound come on well, If so the fault is relative to the output stages, look for components heating up, dry soldering due to this heat cutting off the connection.
However if there is no picture or sound then the fault is in the processor , a test on voltages on diffferent cicuits must be checked when the set shuts down. This will indicate the defficient voltage , possible in the power or output board.
Sep 16, 2010 | Philips Magnavox 27MS343S 27" TV
My vs-45609 tv, when turning on only stays on 30
your main power assembly has blown a heat sink
the board runs around 2-300 and unless your very good with electronics, I would call a repait man...
Check your labor costs and add that to board cost
if you look around you might find a good guy that can get it done in just a few minuts and less than a hundred.. I live in Mass and 79.00 is my hourly labor for this repair..
Oct 24, 2009 | Mitsubishi VS-45609 TV
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Nov 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Apr 06, 2008 | Televison & Video
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Problem turning on
Check that the large fan in the back is working when you turn it on. If not, the set will shut itself off
Sep 20, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
