Question about Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook
When you switch it on after some times then it goes off at ones on less you switch on agian it will work then it goes off again
  • 181 Answers
Check ,, start control panel, power option, making sure the laptop is set on all the time. is the power supply lit on and in the bottom screen saying full charged. if all these are ok the it probably on of two this a virus or a malfunction on the board.eg. prossessor,memory
Posted on May 15, 2009
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP...
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
Jan 08, 2011 | Heating & Cooling
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
My xbox well turn on but as soon as i plug the visual cables in i get 3 red rings then it goes to a blck error screen the error code is E74
you need to send your xbox into microsoft. They cover it for three years and will pay shipping and all.
There is a fix tricks to get it working agian but It will end up breaking agian. When they fix it you will get a new board (most of the time) and it will help for this to not happen agian.
For Microsoft customer service call: (800)4-my-xbox. They will take care of you.
There are a lot of things you can do that are easy and free to help prevent this. See the tips area on this site.
comment back with any questions.
Mar 21, 2010 | Microsoft Xbox Console
Rear air suspension every now and agian go down one side
Probably an air leak in one of the bags (£100 or so), should replace it as your compressor will be working harder than it should be, and will eventually also fail!
Could also be the height sensor (£35) but that is less likely.
Jan 12, 2010 | 2001 Land Rover Discovery Series II
No power to heat and air panel..but heat still works as if it was stuck on defrost. blower fuse is missing will replacing this make panel work agian?
This is a good possibility. When the fuse and or the switch resisiter goes faulty the system will default to a single speed defrost only...
Dec 10, 2009 | 1993 Eagle Vision
Kenmore 22' bottom freezer refrig-freezer not cold
i changed the overload relay- is it possible that a dusty underside of the refrigerator is causing insufficient airflow over the evaperator coil makeing the unit work harder? I also noticed the relay was discoloured when i took the old one appart, but never the less the unit works great. The part cost me 17.99 plus tax at Sears, it took me no time to get the relay off and replaced. cool huh
Jun 13, 2009 | Kenmore Refrigerators
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
