Question about JVC AV-27D305 27" TV
JVC AV27D305-SL
My TV flips 3 inches of the top part of my screen upside down. Can anybody make a suggestion on how to fix it.
  • 156 Answers
REPLACE TTWO ELECTROLYIC CAPACITORS 100MFD/35V NEAR BY THE VERTICAL IC.
Posted on Oct 27, 2007
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Jun 10, 2017 | Sharp Televison & Video
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Top 3 inches of screen have horizontally flipped
that Good , you are a n electronics technician , check capacitors and resistors in vertical circuits ,
Sep 24, 2009 | Philips 27PT9015D 27" TV
Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Mar 21, 2009 | JVC AV-27D202 27" TV
Can I get an upright image with camera mounted upside down
Flip the image in post. Most editing programs have a vertical flip effect that will fix everything
Jan 29, 2009 | JVC GR-SXM260U Camcorder
TOP OF PICTURE FLIPS DOWN VS-50605
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Problem with JVC TV
Do you know how many JVC models are out there ?? To give you useful advice, I need your model number (on the back cover).
Feb 25, 2008 | Televison & Video
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
JVC AV-27D305 27" TV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
