Question about 3Com (3CRWE51196) Router
Router works on and off.
I use a 3com OfficeConnect 3CRWE51196 router to connect to the internet. The router is in turn connected to my ADSL modem. Both work as DHCP. When I connect directly to the modem with an ethernet cable, everything works just fine, but when I set up the router, internet starts acting strange: pages load incompletely, and more often than not I have to press "refresh" three or four times before the page loads. I use a WEP 128bit encryption, but neither turning off the encryption, nor the firewall solves the problem. Any idea what might be wrong?
    Diehard:
    Visited the website for 60 consecutive days.
  • 3Com Master
  • 631 Answers
Turn off dhcp on one of them.
Posted on May 04, 2017
Cameron07
  • 110 Answers
SOURCE: Connect XBox 360 to 3CRWDR200A-75 wirelessly
What fails when you do a Xboxlive test?
Posted on Oct 19, 2007
SOURCE: Router stops responding with red alert light turned on
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
http://booobi.googlepages.com/uperJerry_V2.8b4_Worldwide_A.rar
Posted on Oct 24, 2007
Guys,
There is a new Firmware version 3.1 Beta release that is fixed lots of problems, though this version is unofficial and not yet released on 3Com website.
Download link: [url]http://aragostabbs.altervista.org/request.php?37[/url]
Enjoy!!!
Version & Build Date
3.1/ 2007/10/17
Modification
1. DSL code base update to 3.10.02.
2. ADSL phy driver version : A2pB022g.20H.
Bug Fixed
1. Java script error in Internet Setting page.
2. Dyndns and No-IP are Unworkable. Can not update server ip address.
3. Some gif link can not finish after added DDNS configuration.
4. RIP seems unworkable, Can not enable this function.
3.0/ 2007/9/24
Modification
Bug Fixed
1. ‘%’ issue in username and password.
2. DMZ cannot be removed.
3. Internet WAN add/modify UI error
4. IPSec unworkable. Can not to add and save IPSec Configuration.
5. Can not edit and cancel Port Mapping Configuration.
6. Change login timeout value, does not need check a password.
7. ALG Link unworkable(Removed).
8. Dyndns and No-IP are Unworkable. Can not update server ip address.
9. It does not arrive at the DDNS service which I set. Same issue in the TZO.
10. RIP seems unworkable, Can’t to enable this function.
11. If input ASCII value excluding 0-9 into year field, Current time will save and change to the “1970 0:00:00”.
12. “URL filter” Priority must higher than “PC Privileges”.
13. Content filter seems unworkable.
14. SIP Filter seems unworkable.
15. Some attack can’t be “Intrusion Detection” blocked. Ex: syn flood, ping flood, UDP flood.
16. At Internet Settings -> WAN page, if i enable the option "PPPoA" in Connection Parameters table, the IP Address field will display "undefir".
17. PPPoE does not work.
18. In WAP-PSK When the input value includes?’?, Encryption Function will crash.
19. A “Channel” item of Device Info information is not displayed normally.
20. Channel range is not correct.
21. Can not to disable “Radio” Function.
22. If DHCP lease table status is an “Expired”, a table will has some wrong.
2.9B_ A_SH_DATA_PUMP_20H/ 2007/9/13
Modification
Bug Fixed
1. Virtual server cannot be removed.
2. ROUTER ADSL PC Anywhere will not pass.
3. Java script error on E-mail alert function.
4. Java script error on Internet WAN setting function.
5. Java script error on WPA-Radius server function.
6. Add Jordan in country list.
2.9/ 2007/7/20
Bug Fixed
1. 3Com the 5th UI refine.
2. Support 3 more DDNS secrecies.
3. Support ‘-‘and ‘,’ for virtual server.
2.8b8/ 2007/6/8
Bug Fixed
1. debug firmware to dump memory information.
2.8b7/ 2007/5/15
Bug Fixed
1. failed to connect to device after unplug cable.
2.8b6/ 2007/6/5
Bug Fixed
1. DMZ entry Patch.
2.8b5/ 2007/5/15
Bug Fixed
2.8b4/ 2007/4/30
Bug Fixed
1. Support special characters for PPP username and password.
2. Support WPA-PSK with special characters.
2.8b1/ 2007/4/13
Bug Fixed
1. Fix UDP block port configuration lost problem.
2. support flexible schedule rule.
2.8b/ 2007/3/30
Bug Fixed
1. Fixed IPoA setting cause “out of memory” problem.
2. Add reboot log for debugging purpose.
3. Modify version name format.
2.8a/ 2006/12/22
Modification
Upgrade dsl driver.
2.8/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Modify schedule rule.
2.7d/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Please refer to SG GUI review pt 3.xls.
2. Disabled SIP ALG at default.
2.7c/ 2006/11/22
Bug Fixed
1. DHCP assign range problem.
2. DHCP fixed IP assign issue.
3. DHCP lease table not line up problem.
4. Turn one DNS proxy if NAT disabled.
5. Modify telnet session welcome message (BCM 96348 ADSL router to 3Com ADSL router).
2.7b/ 2006/10/27
Modification
1. Change system objects ID to 1.3.6.1.4.1.43.19.16/17.
Bug Fixed
1. LAN subnet mask shows up invalid error if set the correct value.
2. DHCP IP range assignment did not check weather is on the same subnet or not.
2.7a/ 2006/10/20
Bug Fixed
1. UI pop up warning message about DHCP IP range assignment.
2. LLC and VC/MUX display error.
3. Add DNS server to PPPoE and PPPoA.
4. Instability issue.
5. Login error while type correct password and press enter.
6. Upgrade countdown seconds is missing.
7. PC in different subnet unable to connect SNMP.
8. Lose System log settings after reboot.
9. Directly open file while saving configuration or log will cause open empty file.
2.7/ 2006/10/05
Modification
1. UI modification according 3com’s request.
Bug Fixed
2. Fixed Matis bugs. (Refer to mantis bug system)
2.6/ 2006/9/26
Modification
2. UI modification according 3com’s request.
Bug Fixed
3. Fixed Alert light on system hang problem.
2.5/ 2006/9/8
Modification
2.4a/ 2006/8/28
Modification
Bug Fixed
1. Set NAT default setting to enable.
2. Display URL block message.
3. Modified settings to apply right away. (only partial settings, some of settings still need reboot)
4. Wizard does not “pop up” after upgrade or reset to factory defaults
5. “OfficeConnect” banner in blue does not cover entire width of page.
6. Fixed channel in worldwide version.
Posted on Nov 14, 2007
SOURCE: 3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Posted on Apr 08, 2008
  • 68 Answers
SOURCE: OfficeConnect Wireless Router: I lose my 3com wl-552 wep key. How to know it?...
Please go to the router page and enter in to wireless security option. You will be able to see your password which you entered earlier.
Posted on May 05, 2010
I cannot conect to the internet! My connection is working
need more info, try turning off your comp, modem and router all at the same time for about a minute. Start up the modem, first, then the router, once the modem is completely up. then lastly turn on your computer
Apr 19, 2011 | 3Com OfficeConnect® WL-537 Wireless Router...
I have used my 3com office connect for router with
from my own expierence ive learned that vista supports very few programs. why i dont no. ive had the same problems my husbands pc runs windows xp and the router links to his no prob. try goin on thte router site and down load a new driver from the vista pc. and try reloading if not im sorry but you will have to purchae a newer router vista compadible
Sep 13, 2009 | 3Com OfficeConnect Router
I bought a 3com 3crwe554g72 and when it connect with my ADSL modem the speed will become very slow (-50%). I update to the lastest firmware but no help
3com used to be good things back in the old days. But this hardware is probably self destructing in some way (the problem is widespread, the manufacturer claims it is an old product and gives no solution). Do NOT buy network products from 3com (HP today). Correct me if I am wrong..
Aug 11, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Automatic restart of the router
try checking ur modem button or reinstall windows .if problem presists then contact me at afzaalafridi@rocketmail.com
Apr 30, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Limited Connection
shut off the router then turn it back on again.
Jan 27, 2009 | 3Com OfficeConnect Router
3com wireless router and Sympatico
well you could probley find a better router that the model you have it is probey a older model and probley will not work on some computers.
Jan 03, 2009 | 3Com OfficeConnect Wireless Router
Mar 20, 2008 | 3Com OfficeConnect Router
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
3Com (3CRWE51196) Router Logo
77 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
