Question about Lowrance Globalmap 5200c Color Chartplotter
Can I connect NASA AIS engine to a Lowrance 5150c chart plotter?
If it is possible what should be the baud settings on the chart plotter and what is the wiring connections.
Thanks
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
Problem with st1000 trying to go wrong direction using hds5
One of the settings is 180 degrees off. Go back through the manual and check all of your setup settings. I had that happen once to me.
Dec 03, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
5150c demo lowrance
This is a common problem with Lowrance products. Unfortunately they only service their product for seven years after prduction date. You might check with lowrance to see if you can get the unit serviced but most likely you will need to replace the unit.
Jul 16, 2013 | GPS
Lowrance hds-5 will not power up. lowrance will not work on if out of warranty. does anyone?
most the time its a bad key pad when unit wont power on and what it cost to repair you can buy another one check the pins in the power cord see if there not broke or bent yes they break take a 12 volt test light see if you have power going to power in the plug that connects to back of unit if you have power . . .bad key pad
Feb 25, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
Charting a route on water
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Jul 18, 2012 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
Just updated to the last version 4 of firmware. Depth reading are wrong, say 48 meters when it's only 2 meters.
Check for depth offset, there may have been an unintended change that altered this setting. This setting compensates for draft....
Jun 21, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance Globalmap 5200c Color Chartplotter Logo
311 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
