I have a skyworth v12 engine 32L16hc and I can't unlock the remote control and when i press the botton on TV it appears child lock...How can I make my video1 work again and the remote conrol?
Jun 25, 2013 - Turn on your TV. · On the remote, press the Menu button. The Set-Up Menu appears. · Scroll to the Key Lock function and set function to Off. · Press ...
1 answer
Dec 26, 2012 - How to Unlock panel Key skyworth LED TV Model 32E65 Lock Panel ... down cursor to select "panel lock" then select right cursor to switch off ...
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
CHILD LOCK
The Child Lock feature prevents unauthorized viewing of the TV. To activate, press and hold the F key, and
then press MUTE. You should see a key symbol appear on the screen. This will lock out all remote functions
(except for Standby). To unlock the TV, press and hold the F key and press MUTE. This will unlock the TV.
Please note that the only way to activate or deactivate the Child Lock feature is via remote control - please
insure that it is stored securely.
CHILD LOCK
Guys it's really easy just press on-off and tv at the same time, until de on-off botton turns on. Point the Remote at the TV DVD or SAt and press it 3 sec max. until the tv turns off. then press the stop button and that's it...
To unlock the Panel Lock,
Parent Lock, or Child Lock, follow these steps:
Turn on your TV.
Menu appears.
Scroll to the Key
function to Off.
Press the Exit button to exit.
Note: If you don't have a remote, you may
be able to do the same thing by pressing the Menu button on the front or side
panel of your TV and using the volume or channel up and down buttons on the
TV to scroll to the Key Lock function and set it to Off.
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
