Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony wega i shined a flashlight through the lense behind the bulb after taking out bulb will it mess it up?
  • cdub740 May 19, 2009
    thanks
    i took the optical block out and cleand the intake fan and the exaust fan do you think this will prevent the optical block lcds from going bad?
  • Anonymous Mar 25, 2014
    Need HELP TAKING BACK OFFF
    President:
  • 1,348 Answers
No
Posted on May 15, 2009
  • kirtec auto May 15, 2009
    no
  • kirtec auto May 22, 2009
    wont do any harm.the cooler the things run the better.
Sanyo TV no light on screen, hear audio and can change channels
The first thing to do is check to see if the screen backlighting bulb is burned out, to do this shine a flashlight from behind the screen and see if an image is there, if it is the bulb is burnt out.
Feb 09, 2017 | Sanyo Televison & Video
Radio Display is not working but radio does work
Same thing happend to me, on a Taurus. There is a tiny light bulb inside the radio that shines behind the display panel. It was a real pain to get this out, and to replace it. I used a flashlight to shine on to the front of the display to "see" what station I was on, or etc.
To get this led panel to work on your radio, plan on pulling the radio out, and taking the top panel off. Once its off, just look directly behind the lcd panel, and there is a plug, it goes in like a healight bulb, just turn it 1/4 turn, and pull out. Take bulb to local radio shack, or automotive store, to match a replacement to. Good luck!
Jan 03, 2011 | 1991 Ford F150
Trying to locate where the check engine light is located the bulb is missing and we need to replace but can't locate where it is
use a flashlight and shine it on the dashboard instement panel at an angle.. it is going to be an amber (orange/yellow) color .
You will be required to remove the dash board instrement panel anyways to change the bulb... It will be easier to locate when the panel has been removed from the dash... as then you can shine the light into the back side of the instrement panel and see the amber lense of the service engine light more readily.
Sep 29, 2010 | 1994 Cadillac DeVille
Where is the lamp located to replace lamp on this T.V.? Sony Wega 60" LCD MODEL#KF-60WE610
The lamp is located behind the grapy strip in the front of the tv. Look behind the lowere right and left corners and take out the screws, take of the gray faceplate, and the bulb comes out in a "unit" style. take out the old and plug in he new!
Sep 25, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
How to replace rear projection lamp ?
ok first put the back back on and all screws back in unit. The bulb is located on the front of this TV. Now on the back of the unit on each side there is 1 plastic straight head screw on each side of the back of the tv turn these and on the front where the power button is thats a panel that pulls off the bulb is right behind that panel u have to unscrew to phillips screws on bulb case and it pulls right out, the front panel sometimes takes a good little tug to pop it loose just make sure those plastic screws on each side right on the back of tv are loose first. Hope this helps good luck.
Apr 08, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Mar 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Driver Side turn Signal Bulb
There's one more "hidden" bolt. Above and behind the corner of the headlamp, along the top ridge of the fender, there's a hole in the fender lip. Shine a flashlight down in there and you'll see the head of the third bolt. Remove that, and the headlight assembly will slide forward so you can change the bulb.
Jan 03, 2009 | 2001 Audi A4
Red blinking light at bottom of panel indicating lamp replacement
The glass area you see can be cleaned, but I would use ONLY plain water and your soft cloth to clean it
Dec 27, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
