HVAC issues - A/C blows semi-cold air and Heater won't turn on
I live in a Condo and the HVAC system made by First company is located in the ceiling in the guest bathroom. If I set the thermostat to Fan, it will blow air. When I set it to A/C / Auto, it will turn on but it doesn't blow cold air. When I set it to Heat, the thermostat clicks but it will not turn on even at the highest termp. The HVAC system is about 3 yrs old or less.
Any help is greatly appreciated!!!
  • 374 Answers
Hi! there,
there are possible cause in the circuit is the thermostat,since thermostat switch is like a switch of light,when this turn on blower and compressor turn on,if you turn on and no cold your thermostat
is defective.replace thermostat,if run but insufficient cold was feel check the operating current,there is a rated current you can compare it can tell if your freon charged is under charged,this should be done by certified service technician from your service center,have inform from your manual the telephone no. and location have it call.if still under warranty claim it have a nice day.
Posted on May 15, 2009
My heater blow out cold air
I would guess the blend door motor. You HVAC system can be scanned for codes.
Dec 11, 2016 | Dodge Nitro Cars & Trucks
Air Con
no the pipes should not be cold and wet but if you just have stop using the aircon recently it will do that for a while till all the gas is out of the system so yes its sorta normal
Oct 02, 2008 | 2001 Chrysler PT Cruiser
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
The heater in my excel blows cold air only . The dimist still works just no heat what should i look for?
There are several things that you can do about a heater blowing cold air, but if you keep running into problems then it might just be time to call in a heating repair company. If need be, here is a useful article on: HVAC installation cost, and how to get a fair price. How serious of an issue this is depends greatly on where you live. If you live in the north (Bozeman, MT, etc), then I'd recommend you have your furnace inspected annually to ensure that it is working properly. I'd also recommend that you install a backup means of heat...just in case. ASM has over 25 years of heating and air conditioning experience. If you have questions about a heater blowing cold air or any other HVAC related topic, try the ASM Air Conditioning and Heating Blog or if something your contractor is telling you seems expensive or doesn't sound quite right, consider using our Online Air Conditioning Consultation Service.
Jul 27, 2016 | Cars & Trucks
Fan blower blows cold and hot air
most likely a stuck heater tap,but may involve vacum or elec controlled trap doors in HVAC system
Mar 15, 2015 | 1999 Dodge Dakota
Have a 2003 gmc yukon that blows air out of the vents but will only blow cold air
Coolant in system ??
Coolant flowing through 'Heater Core' ??
Code(s) present w/Scanned ??
Possible HVAC issue(s);Blend air door n HVAC box (Under Dash)-Temp Actuator-HVAC control head @ dash.....
Feb 15, 2014 | 2005 GMC Sierra
Heater not working
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | 2001 Ford Taurus
05 ford ranger 3.0......if I put my thermostat on cold...the vent blows hot air..on max ac..its cold air..makes no sense right....help
Cold air like, really cold or just cool. Sounds like your hot/cold blend door motor has perhaps failed with the blend door in the semi hot position. Blend door motor failure is very common on the Ford truck HVAC systems. Is is located behind the glovebox on top of the HVAC housing assembly.
May 19, 2011 | 2005 Ford Ranger
Heater blows cold air
generally if your heater blows cold air, three things can cause it. 1: very low coolant (anti-freeze) levels, your car would generally overheat tho if at those levels. 2: car HVAC systems have a fin inside which turns to allow either your hot or cold air to pass thru, to check for this just turn your air con on high with the temp turned to hot, this will go cold if this is the case. 3: blown heater core. this is generally a costly repair on any car as they are generally installed midway thru assembly, so removing parts to gain access is a time consuming and difficult task.
All these issues are quite difficult to repair if you do not have the appropriate level of training. I would reccomend taking your car to your local mechanic. although due to the complexity of fixing a heater core ( usually you have to drain your A/C) this can be a very expensive repair.
i hope i have helped cheers
Jan 11, 2011 | 2002 Dodge Grand Caravan
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
