Question about Canon imageRUNNER 8500 Copier
E001 I have replaced the main and sub thirmistor and the dc controller pcb. And a E00003 comes up. Thanks Ed
This machine has an fiery board .Replace the battery which saves the setup info to bios then clear the DC con from clear menu in service mode .This will 100% work if the problem persists after replacing the ehermistor if this has been done please give me the report to me on my mobile 091 9850776781 name s g bendre ( INDIA )
Posted on Nov 23, 2008
Clean a place where unit1 and body machine
Posted on Oct 01, 2008
    Sniper:
  • 54 Answers
First clear the error in service mode. as follows COPIER>FUNCTION>CLEAR>ERROR>OK.
Posted on Aug 03, 2008
  • 62 Answers
Check the fuser rollers for wear. When this occurs the rollers lose their roundness and get flat spots on them. This can cause the thermistors and thermal switches to bounce on thier surface and get incorrect readings. Should replace upper and lower fuser rollers every 150,000 copies (A4).
Posted on Oct 16, 2007
Wat is error 000100 0001 on canon ir 2230
E001-0001 The temperature of the fixing assembly is abnormally high.
The hardware circuit detects overheating of the main or sub thermistor for 200 msec.
To fix it: Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. If this not help you need replace the DC controller PCB.
May 05, 2016 | Canon Office Equipment & Supplies
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
Canon ir5000. How do I correct error 732?
These are all list of error code in Canon iR5000/iR6000 more to come, i hope your machines works fine and never get error.
  • E000
Main cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
Jun 02, 2015 | Office Equipment & Supplies
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
Canon ir5075 error code E00014-000
ese are all list of error code in Canon iR5075
  • n cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
  • E001
Dec 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Gets an e001 often
You either have a power problem where the copier is plugged into > switch the plug. Or that you need a new thirmistor & the sub thirmistor. Also possibly a upper fuser roller.
Feb 26, 2010 | Canon imageRUNNER 6000 Copier
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
Need your help
The problem with this code is in the fuser area. I don't have the specific manual for this model, but here's some information from a Canon IR3250 manual: III . Troubleshooting Malfunctions A. Error Codes 1. E000/E003 Thermistor 1) Is the thermistor soiled? YES: Clean the thermistor. Is the thermistor in even contact with the fixing upper roller? NO: Mount the thermistor correctly. Turn off the power switch, and remove the fixing assembly. Measure the resistance between connectors J50B-2 (FSRTH) and J50B- 3 (GNDTH) on the fixing assembly side. Is it between 120k and 290k W? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Main heater 2) With the fixing assembly removed, is there electrical continuity between connectors J50-3 (FSRN1) and J50-5 (FSRL1) on the fixing assembly side? NO: Replace the main heater. Sub heater 3) With the fixing assembly removed, is there electrical continuity between connectors J50-4 (FSRN2) and J50-5 (FSRL2) on the fixing assembly side? NO: Replace the sub heater. Thermal switch, DC controller PCB 4) Remove the fixing assembly, and detach the wiring cover. Is there electrical continuity between the terminals of the thermal switch? NO: Replace the thermal switch. YES: Replace the DC controller PCB. CHAPTER 4 TROUBLESHOOTING COPYRIGHT © 2000 CANON INC. CANON iR3250 REV.0 JUNE 2000 PRINTED IN JAPAN (IMPRIME AU JAPON) 4-43 2. E001 Thermistor 1) Turn off the power switch, and remove the fixing assembly. Then, measure the resistance between connectors J50B-2 (FSRTH) and J50B-3 (GNDTH) of the fixing assembly side. Is the resistance 1k W or less? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 3. E009 Fixing assembly 1) Is the fixing assembly rated at a voltage different from that of the power supply? YES: Replace the fixing assembly so that its voltage matches the fixing assembly. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 4. E010/E011 Connector 1) Is connector J12 of the main motor and connector J218 on the DC controller PCB connected correctly? YES: Connect them correctly. CHAPTER
Jul 02, 2007 | Canon imageRUNNER 3570 Copier
Canon imageRUNNER 8500 Copier Logo
96 people viewed this question
old marine
old marine
