Question about Acer Aspire 2100 (91.AB675.D02) PC Desktop
White screen on my acer 3680
my notebook have problem with white screen , some friend told me to unplug the inverter cable , locate in below the lcd ? , i'm trying to open the casing ... but can get it through , does anyone have a video how to open the casing ?
i'm sorry for may bad english.
Thanks a lot
    President:
  • 814 Answers
This may not be a problem with the inverter , but a problem with the video card. Try hooking up another monitor to you laptop the see if the video card is putting out signal. If you get signal then you can try to fix the power supply for the screen. If you get no signal then you may have a video card failure and have to replace or repair it. There are many videos on you tube on laptop repairs, check these out and it will give you a better idea of the skills and tools necessary to take apart the laptop and perform the repairs. Hope this helps you with your problem.
Posted on May 15, 2009
White screen but plugin monitor works. is it the screen?
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5100/Aspire5100sp2.shtml
http://www.laptopscreen.com/English/model/Acer/ASPIRE~5100/
So you PHYSICALLY checked the connection of the Video Cable, TO the motherboard, TO the screen Inverter, and TO the back of the LCD screen?
Visual inspection will NOT do. If either motherboard connector, or LCD screen connector is loose, the width of this letter -> I < you won't see it, and it will affect the video signal.
The Video Cable connects to the motherboard under the Middle Cover, above the F4 and F5 key on the Keyboard. (Left edge of F4 key over to middle of F5 key)
[Middle Cover is Acer speak for Switch Cover. The cover strip above the Keyboard, and below the LCD screen ]
aspire-3100-5100-5600-lcd-cable-dc020007o00-.html
http://www.laptops-we-r.com/prestashop/aspire-5100-parts/109-acer-
Click on the view to enlarge. Top left side connects to the LCD screen. Rectangular Black connector with thick round cable, at the bottom, connects to the motherboard. Small cable coming off at the bottom, connects to the screen Inverter ]
From the motherboard connector the Video Cable routes up under the left Hinge, and into the Display Assembly. It then connects to the screen Inverter, and LCD screen.
From normal opening, and closing of the laptop, repeatedly, the Video Cable may become pinched.
This can lead to loose connections.
It can also lead to damage of the Video Cable.
If the sheath of the cable shows apparent signs of damage, the tiny wires inside may be damaged also.
Stretched/Broken
This means to ENSURE that the Video Cable is NOT the problem, a continuity test needs to be performed on all of the Video Cable's wires. (OHMS)
If an economical multimeter ($5 to $12) is not available, suggestion is to take it down to the nearest 'Mom and Pop' computer store, and have them check it. Labor charge should only be a few bucks.
Video Cable checks out it's on to the screen Inverter, for the diagnoses.
[NOTE*
This diagnoses is for an Acer Aspire 5100 Notebook PC. Uses a single (1) CCFL for a Backlight, and has a screen Inverter. Laptops that use LED's for a Backlight generally do not use a screen Inverter]
Did you test the screen Inverter, or replace it?
http://www.amazon.com/Acer-Aspire-5100-Inverter-PK070005U00/dp/B005F1N5O2
http://www.fonerbooks.com/test.htm
NOTE*
Takes a sensitive multimeter. Read fairly expensive.
Primer;
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor. Suggest start out with your audio turned down ]
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5100 Notebook PC uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
If the screen Inverter is good, the LCD screen is bad.
Replace.
[The LCD screen, and the screen Inverter are a MATCHED unit.
When purchasing make sure you get the correct screen Inverter, or LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 09, 2012 | Acer Aspire 5100 Notebook
Blue screen on notebook monitor when hooking up external monitor
hold dowm the Fn key and keep tapping on the F5 key..
Jul 05, 2008 | Acer Aspire 3680 Laptop
Acer aspire laptop 3680 backlight turns off after it has been on for a good while leaving screen black.
The inverter is over heating or going bad. It is cheaper to replace the inverter than buy a new notebook.
here is the website for the part.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2872&zenid=37cdde6575a08197f41dc330b628c5a4
I would have a tech install the part.
Aug 15, 2009 | Acer Aspire 3680 Laptop
My lcd screen on my acer aspire 3680 loks like a negative
You only replace the inverter board when there is no light coming from it. E.g. in a dark room you cannot see any light from the screen. But it sounds very mutch like a cable rather than the whole LCD try and get a cable first it will be LOTS cheaper.
Hope this helps
Apr 17, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 white screen
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
Mar 30, 2009 | Acer Aspire 3680 Laptop
Need Acer 3680 VISTA all driver
Below there is the download page for your laptop from Acer.
Acer Europe - Service & Support, Drivers & Utilities, Downloads
Download drivers on the Vista section in page.
Remember to rate the solution.
Thanks.
Feb 18, 2009 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
ACER 3680 2022 LCD SCREEN PROBLEMS
It may not be a problem with the lcd.
This is most likely a problem in the video card of the laptop.
but you can test it out, if you plugin a extra screen to the laptop to see if the white dots come to the other monitor aswell.
If you see white dots in both of the screens this means the video card is about to fail. and would need to be replaced.
If you don't see any white dots on the external screen then the problem is in the lcd.
You can call bestbuy they should give you another phone number to call for repairs / parts.
Jun 10, 2008 | Acer Aspire 3680 PC Notebook
No light on screen of acer extensa 4620 4605 PC notebook
This is a problem I have experienced with my HP laptop as well. I found some info on this and was told that it was the inverter. I managed to fix this by finding the inverter and, unplugging both ends of it and plugging it back in. This fixed the problem and a week later its still working!
The inverter is usually located at the bottom of the screen. To access it you need to unscrew the screws around the screen. This will involve removing the plastic covers and simply unscrewing them.
Once you have removed the plastic cover from around the screen, you should see the inverter at the bottom. Re-seat the connectors, and see if this fixes it. If not, replace with inverter. The site below is an example of where you can buy one.
http://www.laptopbacklights.co.uk/
This may help you with the process
http://www.laptoprepair.co.uk/how-to-repair-backlight-inverter.htm
Hope this helps, let me know
Jun 02, 2008 | Acer Extensa 500T Notebook
CHANGING INVERTER
Always make sure the power cable is unplugged and the battery is removed before stating. The inverter is usually always right beneath the screen on most notebooks. Peel off the rubber pads or plastic covers around your screen to reveal the screws. Once all the screws are out you should be able to pull the plastic bezel off the screen. Sometimes seems stuck so pull hard but not hard enough to break it. The inverter is the little board below the LCD, usually has a cable pluged in at both ends and a few little screws holding it in. Remove the screws, unplug the cables. Reverse the process and hopefully your backlight will come on.
Jan 10, 2008 | Acer Aspire 1705SMi Notebook
Open Questions:
Acer Aspire 2100 (91.AB675.D02) PC Desktop Logo
315 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
