Question about GE WPGT9360EPL Top Load Washer
HELP, GE profile harmony washer wont drain properly
My ge profile harmony washer does not drain properly. We undid the hoses and its all clear however it seems the pump may not be functioning because it will drain into the pots but only if we do it by hand.....unlike the machine/pump doing it. Any thoughts? Is it the pump or can it still be something else?
  • 4 more comments
  • Julie Stratton
    Julie Stratton Dec 08, 2007
    I started a load like normal and left the room for a while. When I returned an error msg said that a problem has accured with the unit. I couldn't push any buttons it just beeped. The tub was still full of water and couldn't tell whether the clothes had washed or not. So i'm not sure when the problem accured. I tried to do a quick spin to drain the water and it made some noise for several seconds and then the error msg again. Please tell me it's minor!
  • Anonymous Dec 30, 2007
    wont drain
  • JCBJr Feb 06, 2008
    Washer works well for a while then it starts this trouble draining again, give us a problem for a day or two then works. I get the error message, hold the pump test button for a while and occasionally it drains. If not I open and close the lid a few times and it will start to work after a couple trys. I sure would like a real fix for this thing......
  • mathqueenb Feb 17, 2009
    mine constantly tells me the load is out of balance! All the time. It is getting ridiculous.
  • bgrayson90 Mar 29, 2009
    Same situation here. I replaced the pump (it was not sounding right), but even after that, it claims it is not draining properly. I've disconnected all three hoses (exterior, pump-to-exterior, and tub-to-pump), and made sure they are all clear, and also took out the pulsator and checked in there. The only thing left is to take the whole tub out in case there's a sock between the tub and the outer tub or something. Any other ideas?
    My thought is that whatever is causing the problem, caused the first pump to end up burning out part-way, but I obviously haven't solved it yet, and I don't want to ruin another pump.
  • Anonymous Apr 01, 2014
    LOOKING FOR DRAIN PUMP FILTER
    Scholar:
  • 146 Answers
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Posted on Nov 09, 2007
  • echomania Sep 16, 2010
    Mine failed too. The pump motor has strong permanent magnets that will cause the motor to have resistance every 180 degrees of rotation, but that appears to be normal. I removed my pump and connected it directly to AC power, and discovered that it would only start on its own intermittently... it didn't always have enough force to overcome the resistance of the magnets. If I carefully started rotation with my finger it would run OK. So, it's time for a new pump.
  • jsdkt Jan 25, 2011
    Just wondering.....did the new pump solve your problem? We have the same issue, and are debating......new pump(cheaper option), or new washer. It seems this is a GE quality problem that is affecting a lot of people.
Ge harmony washer says there is a problem been detected how do I clear it
The Ge washer claims it has detected a problem. How do I clear it? There doesnt seem to be anything wrong with the unit.
Aug 26, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I have a GE Harmony top loader washer all digital. My washer will not drain throught the drain hose. I have to lower the hose to the floor for the water to come out any ideas
Your pump might have something in it. I got a shoestring out of one the other day. Remove the front panel and inspect the pump.c8963d3.jpgbottom right of the photo is that clogged pump, The top does not pop up. The front panel comes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 17, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
My ge profile harmony will not spin and drain
I AM NOT A MECHANIC (THOUGH I WISH I WERE), BUT IT SOUND LIKE YOUR BELT OR MOTOR COUPLING. I DON'T WANT TO TELL YOU WRONG. I AM NEW AT THIS STUFF. I HAVE BEEN AROUND WASHERS ALL MY LIFE TO KNOW WHEN THEY BREAK DOWN AND NEED TO BE REPAIRED, BUT MY DAD (WHO DIED IN 2006), SPENT MOST OF HIS LIFE REPAIRING MINOR PROBLEMS ON WASHERS. GOOD LUCK.
RODNEY
Apr 29, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE PROFILE
It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
WASHERS WILL START
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
1,982 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
