Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I want to connect my phone de connect internet but il haven't windows wista X 64 driver Modem : JOA mobile phone kabore.evariste@yahoo.fr
  • 557 Answers
Google for vista X 64 modem driver and several links wil display
Posted on Aug 16, 2009
Can i use Samsung omnia i900 windows phone as a modem to connect to intenet?
1. install the Samsung Omnia modem driver on your Windows PC - can be found @http://www.samsungmobile.com/promotion/omnia/fr/sub02_xp.jsp
2. if you have installed Active Sync on your Windows PC then make sure that before you connect your mobile device to PC you disable "Allow USB connections" from the Active SyncOption menu
3. after you connect Samsung Omnia to PC, on your mobile device go to START->PROGRAMS->INTERNET SHARING and select the connection type (bluetooth or USB - most commonly used would be USB); tap "Connect". Your Samsung Omnia will connect to the mobile network if you have set up a profile for GPRS/HSDPA according to your billing plan provided by the network operator.
Feb 27, 2011 | Computers & Internet
I want 7339 modem drivers
contact me prajwal_yes@yahoo.com
Jan 23, 2010 | LG KP200 Cellular Phone
Pilotes
bjour j'ai un pb avec mon ordi après l'installation de windows XP SP2, il n'ya plus de son
Sep 01, 2008 | Packard Bell Easy One Silver 2101 Notebook
Prbl?me de d?tection
1-etre vous sure que l'attachement est fonctionel? essayer un autre
2-votre PC doit vous dire qu'il ya un appareil externe qui est connecte
3- ensuite vous installez le driver essayez ces sites gatuits pour votre driver
http://www.printcountry.com/drivers/SAMSUNG_SF_5100_DRIVER_DOWNLOAD.htm
http://hubpages.com/hub/Samsung-Printer-Drivers
Aug 28, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Moden of huawei ETS 2288 WLL
n wista also huawei driver works,,i too tried to install wista drivers for huawei but in vain ..no problem in xp driver itself it will work,,,if it works mail me at aravindterror@gmail.com and don't worry it will work conformly because now im using ny connection in wista using huawei only..
just follow the step to do it:
1)install that driver setup and warning the usb port from modem should be disconnected during this
2)install will finish and wait's for usb port to be connected by displaying port not found,
3)now plug the usb cable and inbuilt windows will appear and say found new hardware and install from the location where you had whether from cd or from hard drive,select appropriate option.4)if it says error during installation ,
4)goto my computer right click and select properties and select device manager in that under other devices categorie you will found your device with question mark,right click that and select update driver and selec from the location where you have that driver back up i.e from cd of location in hard disk..then it will finish installing software and once again it wil ask if automatically it finishes secon time installation no problem or else follow from step 4)
5)now your usb will be identified by your huawei installation process and say port found click next and it will finish setup
6)then once again goto my computer and then right click and than goto properties and device manager and right click on your name at beggining then select scan for hardware changes,,that's all finishes..
7)select connect to from your wista and select new connection and select connect to internet in that dialup ,enter your dial up phone no,username and password..then it will connect....ha ha..
Jul 23, 2008 | Computers & Internet
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
UNLOCK SAGEM MY W-8
imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Oct 24, 2007 | Lands Phones
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
1,260 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
