Question about Microsoft Windows 98 for PC
TOSHIBA SATELLITE PRO 430CDS WON'T TURN ON
HARDDRIVE FAILED. I FITTED ANOTHER HARDDRIVE. NOW WHEN I PRESS THE ON BUTTON THE GREEN "ON " INDICATOR
AND THE POWER CABLE LIGHT BOTH FLASH ON FOR ABOUT ONE SECOND THEN GO OFF. THEN THE POEWR CABLE LIGHT FLASHES ORANGE CONTINUALLY. EVEN WITH THE POWER CABLE DISCONNECTED I TRIED A BOOT DISK IN THE FLOPPY DRIVE STILL NOTHING I REMOVED THE BATTERY FOR 24 HRS STILL NOTHING
PLEASE HELP
  • coadym May 20, 2009
    LATER INVESTIGATION IT APPEARS THE VARIOUS VOLTAGES TO RUN THE COMPUTER ARE SUPPLIED VIA THE BATTERY PACK. FROM THE 10 BATTERY CONNECTION POINTS, WITH A VOLTMETER I CAN ONLY GET 1.5VOLTS BETWEEN CONNECTORS 4&7 AND 1.4 VOLTS BETWEEN CONNECTORS 7 & 9 COULD IT BE THE THE VOLTAGE REGULATOR IN THE BATTERY PACK IS THE PROBLEM?
  • 431 Answers
Sounds very much like either the HD plug is incorrectly posistioned ( pins maybe one or two places to left or right due to a bent pin .. ) or the HD has been installed upside down .. unlike the 3.5" ide plugs very few 2.5" have position guides to stop you from inserting the HD incorrectly and due to their small size and awkward fittings this is exceptionaly easy to do . Another thing that sometimes happens is that the soldering joints on the ide socket wouldnt pass any exhibition displays and are flimsyly attached and become loose due to the preassure of the new hard drive being inserted if this is the case special soldering equipment is needed to resolder the ide plug on the circuit board .. and shouldnt be attempted by the untrained unless you can afford a new computer as static and error damage by the layperson are a service engineers biggest pay packet boost . Changing a hard drive is one thing soldering on a multilayered circuit is something else ? . I hope this has been of help to you Regards Vortash
Posted on May 15, 2009
  • clive pearson
    clive pearson May 20, 2009
    possibly but it should not affect the sysytem unless it was a direct short if you are running on your power pack ie maims adapter the computer should still run even without a battery in .. it has its own power supply distribution .. and the battery should only really be a concern if you are trying to run the computer on it . Take the battery out and you will see that the unit will run on the mains power supply alone see if the fault clears if it does then your battery is short and dragging the power down .. Vortash
Toshiba Sattelite PRO L300 telling me checking file system C one of disks needs to be checked However it then says an error has occured and won't leave this screen !
Press F8 and choose command prompt.You may have to use a boot disc if you can't get c prompt.
Type cmd ENTER. From the Command Prompt type chkdsk /r/f ENTER. R and F are redundant for repair and fix, but does not hurt.
Oct 29, 2012 | Toshiba Satellite Pro L300 Notebook
Replaced harddrive on toshiba satellite loaded windows xp now all it does is reboot
Check in the bios (press del or f2, f11 somthing like that on start up to enter bios) Chech what disk access mode is set, try AHCI.
If that fails "google fix master boot record XP"
Oct 03, 2012 | Toshiba Satellite L455D-S5976 Notebook
Hi! I've got a Toshiba Satellite L300 and it won't boot anymore. I get past the initial toshiba-screen where I can press F2 and F12 but afterwards there's just a black screen with a little...
You can retrieve your data by removing the hard drive and connecting it to an USB hard drive adapter then plug it into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files to back up your data.
You can then return the hard drive back into the Toshiba then format the hard drive and reinstall Windows to get your Toshiba working again.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
We have toshiba satellite pro laptop which was working fine. Now it will not turn on and the caps lock, f10 and f11 lights are illuminated even though laptop not turned on. Nothing happens when we press...
Remove all power sources.
Remove hard drive and Ram.
Fit AC adapter and press on. If the laptop complains as there are now no periferals, power down the laptop.
If it still dosn't power up at all, you have a motherboard fault and cannot continue. A Toshiba Computer Repair Cetre will help you out.
If it did work;
Disconnect power source.
Fit RAM and try again. If that still works but now states that there is no OS, power it down and with power source removed fit the hard drive.
Power up again with AC Adapter. Hope fully all now should be well or at least you now know where your fault lies.
I hope that helps.
Dec 30, 2010 | Toshiba Satellite A60 Notebook
I have a toshiba satellite pro 4600 - no power at the display or lights - the power supply is working?
yes youre right, the power supply or the motherboard is not working. You can try to press and hold the power button for 8 secs to turn it on. If it is still did not work, call toshiba for possible power supply or motherboard laptop repair...
Nov 12, 2010 | Toshiba Satellite Pro 4600 Notebook
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
My Toshiba Satellite PRo L300 won't shut down.
SIMPLY REMOVE BATTRY AND POWER SUPPLY
reconnect them
go to power options and check setting
"when i press power button"
select shutdown
May 05, 2010 | Toshiba Satellite Pro L300 Notebook
NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 22, 2009 | Ultra Computers & Internet
What is the power button for toshiba satellite pro 4600
hi..the power button is available on the top
of the laptop.It willl be indicated with the
red symbol on it.
check this out..
thank u..
rate me..
Feb 21, 2009 | Toshiba Satellite Pro 4600 Notebook
Microsoft Windows 98 for PC Logo
239 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
