Question about LG Heating & Cooling
My LG reverse cycle is not working. It turns on fine, but then switches itself off about 5 mins later and flashes "ch 5".
    Genius:
  • 1,847 Answers
Get all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit...
let me know the status.
Thanks.
Kevin
Posted on May 15, 2009
  • Legin Varghese
    Legin Varghese May 15, 2009
    Sorry Check the wiring and connections
    Thanks
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
My LG split system Model S24AHN switches itself off after a minute or 2 and CH 5 flashes on the screen. What cause this and how can I fix it?
It's communication error between indoor and out door. Make sure you have command from indoor by checking volts in out put of indoor or in put of out door. If not, Check your PCB and also loose connections.
Dec 19, 2010 | LG Heating & Cooling
I have an lg Rumor 2 phone. It is supposed to automatically lock the keypad and turn off the screen when it is idle. It does that but within 2 seconds it turns itself on again with the screen on and the...
Hi, when a phone randomly Switches off, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Jul 02, 2010 | LG RUMOR Cellular Phone
I lost the key & transmitter for my 2004 Envoy. Had a new key made at the GMC dealer. Worked great one time. Tried later and it seems the alarm set itself. Cannot get the alarm to disengage thus...
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Nov 17, 2009 | 2004 GMC Envoy
I have an LG RE-44SZ21RD, turns off after 5 minutes of use
It might be worth checking that you haven't accidently activated the tv's sleep timer, I did on my LG DLP !!. always check the obvious first.
Oct 06, 2009 | LG RE-44SZ21RD 44" Analog Television
Cycle selector knob is flashing for all cycles and
After trying the Fixya posted and LG service recommendation of pressing the pause/play button for 5-8 seconds and unplugging the machine for one minute before plugging back in (which didn't work) we unplugged it for over an hour and the computer reboot/reset itself.
Sep 30, 2009 | LG Dryers
Turn on problem in CH-DVD 300
your dvd player is burning out!!!
this happaned with mine & it broke awhile later
i suggest returning it to the store now!
Dec 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Heating & Cooling Logo
52 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
