Question about Iomega 1.5TB Desktop USB Hard Drive
Iomega Prestige 1.5TB external hard drive won't start-up properly
Hi there. My Iomega Prestige 1.5TB external hard drive won't start-up properly after a week of having it. I copied nearly 500GB onto it during its first use. Whn all was done, I turned it off, unplugged it, and then turned it on elsewhere so I could plug it into a newer laptop (Vista instead of XP, which was where I did the copying of data). But wherever I plug it in - even back in the first socket/laptop, it first beeps for a few minutes, and then when plugged in by USB to the laptop, the laptop makes a sound as if something has just been plugged in, but nothing shows in My Computer. In the Vista laptop, I found the hard drive listed under Devices, but I just can't actually find the device or get to its contents.
Iomega - the manufacturer - is shockingly indecent in that they want nearly £20 "per incident", even if they can't resolve the problem; that's what I understand from their website. I have not yet contacted them. I just want to get to the data, because it's from another hard drive that has crashed, so now I may have lost everything, and can't afford to pay "professionals" to recover the data.
Please, help!
Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
Posted on Jan 05, 2010
5 Suggested Answers
  • 4 Answers
SOURCE: 500GB Prestige USB 2.0 Desktop Hard Drive
Try using a different USB cable, also power off the drive and then replug in the USB cable and power up connected to computer.
Posted on Mar 13, 2010
  • 739 Answers
SOURCE: transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Posted on Mar 16, 2010
Testimonial: "First class advice"
  • 211 Answers
SOURCE: dropped my Iomega 500GB Prestige exterior hard
give it to the service center for replacement and dont tell them u have dropped it or els they wont replace
Posted on Jan 10, 2010
bronk50
  • 27725 Answers
SOURCE: iomega prestige 500gb not recognized
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on Jun 01, 2011
Iomega LPHD-UP 500GB power issue?
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly.
I suggest you get a new AC power adapter for this drive.
Apr 13, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Hi there. I have a 500gb Iomega Prestige external HDD. I was in my external HDD files, moving some photos from one file to another (nothing I haven't done a million times before). When I moved one...
you could run the chkdsk utility
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Jun 07, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
I just bought an Iomega 1TB Prestige portable hard drive and every time I copy a single document in Word, PDF, etc from one drive and try to paste it onto the Iomega drive I get an "Access...
Can you copy that single document from the drive to a different folder?
Can you copy that copy to the IOMEGA?
Can you copy that original to the IOMEGA?
Nov 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
How to copy my laptop hard drive to the Iomega Prestige 500GB Compact Edition, USB 2.0 Portable hard drive? I have read the user manual and there are no real directions on how to use this product. Thanks
right click the drive you want to copy
click copy
open your lomega hard drive
right click....click paste
or
right click the file you want to copy
click send to
click the name of your lomega hard drive
Jun 20, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 1.5TB Desktop USB Hard Drive Logo
1,285 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
