Question about Mitsubishi CK-35308 35" TV
Flatline! 35" picture tube mitsubishi tv. 10+ years old. worked fine this morning, tonight- flat line horizontal line thru screen. tuner(sound) still working... whats the most likely problem? is it repairable? is it worth it???
    President:
  • Mitsubishi Master
  • 1,348 Answers
The vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
Posted on May 15, 2009
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Single horizontal line in middle of screen
Yeah, thats the tube, buy a new one. It's 15 yo anyway, let it go ;) Best of luck!!
Aug 31, 2009 | Televison & Video
1992 35" TV has no picture...just a horizontal line
if you fix also not expensive just vertical ic problem
Jun 05, 2009 | Televison & Video
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Feb 03, 2008 | Mitsubishi CS-27205 TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
No picture
Same problem, worked fine this morning and then tonight I million green horizontal bars - sound is fine. I think from reading up on this we are doomed. I am so pissed, the TV is not even 2 years old.
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
289 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
