I have a GE JKP27WP1 Built-In Double oven. The Bake and Broil buttons will not turn the upper unit on. The lower unit works fine. I have an idea that the problem in in the control panel electronics but I am told that the part is no longer available. There is no error code. When one of the buttons are pushed, the time blinks. Anyone got any suggestions.
Hi Cyrep, You can fix a suggested fix at the following link: www.fixya.com/howto/h155060-dreaded_f7_error Even though you are not getting an error message, they are sometime stored in memory and have to be repeated a number of times before they show up in the display. I have shared this fix with over 1300 folks and most report success. I hope that it works for you too. Please let me know at [email protected]. Regards, Charlie
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
I have a GE JKP27 double oven. The top oven will not work at all - when I turn it on, code "F3" & "Door Locked" shows on the display. The bottom oven works fine.
My bottom oven works fine but my top oven does not. All of the lights are lit up on the digital display and I tried the paper trick which did not work. Any other suggestions?
I have the exact problem and tried the paper solution with no success. Not sure what to do.
