Question about Lexmark C510 Laser Printer
83 PHOTODEV CART MISSING
This error still appears  after replacement of new Photo Developer cartridge
Even thou developer was reset in suppliers menu.
I need assents here how to fix this problem.
  • 3 more comments
  • shulesh vinay Oct 15, 2007
    Replaced Photo Developer
  • Anonymous Dec 26, 2007
    Error Message "83 Photodev Cart Exhausted" I have installed a new one and have tried to change in supplies menu. I have also tried unplugging the printer.
  • Anonymous Jan 02, 2008
    I have replaced the Photodeveloper Cartridge and the printer still indicates that it is "exhausted." I have tried unplugging cords, shutting power off, etc.
  • Anonymous Jan 09, 2008
    83 photodev cart missing
  • motleycrew Feb 11, 2008
    I have a customer that has a Lexmark C510 that is getting a message 83 PHOTODEV CART MISSING . I have talked to Lexmark and they said to check the sensors for toner or make sure that they are not dirty . I have cleaned them and still same problem. Please Help .
To specify which supply has been replaced:
  1. Make sure the printer is on and the Ready message is displayed.
  2. Press and release Menu until you see Supplies Menu, and then press Select.
  3. Press and release Menu until you see Replace Supplies, and then press Select.
  4. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  5. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  6. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  7. Press and release Return until the printer returns to the Ready state.
Posted on Feb 27, 2008
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
My Lexmark C510 Laser Printer was giving me- 83 Photodev Cart Warning so I replaced Photodeloper but printer is not recognizing that I replaced it
  1. Press and release Menu until you see Supplies Menu, and then press Select.
  2. Press and release Menu until you see Replace Supplies, and then press Select.
  3. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  4. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  5. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  6. Press and release Return until the printer returns to the Ready state.
Feb 14, 2012 | Lexmark C510 Laser Printer
Hi, I have a Lexmark C510 Laser Printerphotodev exhausted message, changed it and still have the massage! Maybe it needs to be reset? I shut it off and restarted, but still have the message.. HELP!...
The 83 Photodev Cart Exhausted message on the operator panel indicates that you must replace the photodeveloper cartridge immediately. To replace your photodeveloper cartridge please clink on the link below.
http://bitly.com/nG3Toi
Jun 17, 2011 | Lexmark C510 Laser Printer
屏å¹?提示ï¼?83 photodev Cart Exhausted æ??ä¹?å??äº?ï¼?
You need the OPC Image Unit 20K0504 which contains the developer. This is a supply item
Whit
Item, Inc.
Aug 10, 2010 | Lexmark C510 Laser Printer
Message of '83 photodev cart exhausted', where abouts is it, in the machine?
Here's an article in the Lexmark website on How to Replace the Photodeveloper Cartridge in the C510. Just click on this link: http://bit.ly/bOJQDz. Follow the instructions carefully. Hope this helps.
Jun 14, 2010 | Lexmark C510 Laser Printer
Not printing
The problem could be the Developer Clutches not turning the cartridge. Thus toner does not develop and get transferred to the photodev cart. This may be due to a missing retainer clip try replacing the clutches. That should solve the problem.
Dec 09, 2009 | Lexmark C510 Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
2,699 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
