Question about Fuji Rod Repair Kit
Red Light This is so lame of me to ask. Slightly feel foolish for asking. But I have a Fuji battery charger (BC-45) and when I put my battery in it the light is red. What does this mean?
  • 244 Answers
Should mean it's charging. will go out when fully charged. usually takes about 45 mins to charge but depends on battery life
Posted on May 15, 2009
Why do the batteries pop out of the QC-906 battery charger?
I have a feeling that the batteries might be the issue.
They might have dead cells or if they got to hot or cold the battery case can swell a little.
That will cause the issues you are experiencing.
Have A Good Day
Nov 01, 2014 | Ryobi Multi-Volt Battery Charger
Clean spot inside lens
Send it to a camera repair shop. Disassembling the lens is not an easy job.
Feb 23, 2014 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
Can I charge my camera fuji jv100 on my laptop with a usb
No. The NP-45A battery needs a separate charger. If you need a charger, one source is
http://www.overstock.com/Electronics/Battery-and-Charger-for-Olympus-Li-40B-Fuji-NP-45/6042413/product.html
Aug 01, 2011 | FUJIFILM FinePix JV100 Digital Camera
I have an Orange light that blinks after I take a photo and it doesn't allow me to take another one
The blinking light is the flash recharging message. You could try turning off the flash (if the lighting conditions are appropriate for this). In fact if the lighting conditions allow, the camera should default to taking a picture without the flash during the recharging cycle.
The recharge time will be longer if the batteries are low. If the battery is older, it will not hold a charge as well as it did when new and will act like a low battery. Try recharging the battery. If the battery is more than a year old, get a replacement NP-45 battery. If you believe the battery is fully charged, you might need a new charger, BC-45A.
The manual for the J10 is available here: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/j/finepix_j10_j12_manual_01.pdf .
I hope this helps.
Apr 25, 2011 | Fuji FinePix J10 Digital Camera
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Can the BC-NH01 battery charger also charge AAA
In reality, yes. The AAA batteries are to short for the charger, so some fiddling is required. I'd recommend you buy a suitable multicharger instead.
Apr 13, 2010 | Fuji FinePix E550 Digital Camera
Battery Charger
A. Have you checked these first?
1. Is the battery correctly inserted?
2. Is the battery in correct orientation?
B. May be your battery fabrically is not NORMAL.
Your battery NP-45 must be checked. You should control and be sure that your battery is in good condition.
1. You may do it by this way:
You can do it practically by going to the nearest store and take a new battery from there for only checking. When you go to the store please want a permission from them to check your battery. It only takes a minute. When you place a new battery to your BC-45B charger. If the led turns yellow or green but your battery does not do the same then it means your charger is in good condition but your battery is out of order.
2. Also you may do it by another way.
Check your battery with a multimetre if have one and know how to use it.
C. Please buy a new battery and replace with your old one. I looked on internet for you where you can buy from a chipest and a trusted place. On ebay.com it is sold. Please open ebay.com and write on the seach box 370357190515. It is sold from a trusted seller with shipping FREE.
I think your problem will be solved by changing your battery with new one.
If your problem is not solved. Please feel free to contact me again.
Best Regards
Apr 04, 2010 | Fuji Finepix J100 Digital Camera
I got present of finepixz20fd for christmas but received no battery charger when i received it
You should have received the BC-45 charger. You have the option of purchasing one from places like adorama.com and amazon.com
Jan 07, 2010 | Fuji Finepix Z20fd Digital Camera
Fuji Rod Repair Kit Logo
232 people viewed this question
Top Fuji Sport & Outdoor - Others Experts
Nick Olsen
Rick
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
