Question about GE JBP90 Electric Kitchen Range
Wont heat up, but the lights are on
My oven was working and is now not the lights all work but it wont heat up
  • 1 more comment
  • jamesofberke May 17, 2009
    No. we bought a replacement and the same problem, only now the oven wont work either
  • jamesofberke May 18, 2009
    The stove wasn't hot when it cut out, and the replacement also had the issue without ever being hot. I doubt that an identical problem of electrical current (the clock and lights still working) being present and heat not being generated are internal issues with the stoves. I believe it is my circuit breaker, a double 30w, is not completely functioning. If one half of the breaker is not operating correctly will the other stay on and still work?
  • shaun greyvensteyn May 11, 2010
    the plates or inside the oven
It most likely is the breaker. Your stove lights, clock, etc. will still work with 120v feeding in, but your elements will not work without 240v. I would first check the breaker (flip off and then on to reset) If that doesn't correct the problem, use a volt meter to check that there's 240v at the receptacle, there could be a break in the wire somewhere or the breaker could be toast.
Posted on Jun 07, 2010
  • 159 Answers
Check the thermostat switch most cases
Posted on May 16, 2009
  • shaun greyvensteyn May 17, 2009
    check for power on elements if not near the element is a little round safety switch on some of the stoves if the temperature goes up to a certain degrees it cut the power to the elements but does the plates work.
  • shaun greyvensteyn May 20, 2009
    the incoming power goes to your clock and from your clock it goes to your switches are your clock set correctly or take a three core cable and connect it to the stofe and put a plug on and to any plug and see if doubt of breaker
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
The oven isnt heating the lights n the everything else is on but it just wont heat
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 24, 2010 | Maytag CWG3600A Gas Single Oven
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Burners work oven wont light
heatman101
dhdg
May 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
GE JBP90 Electric Kitchen Range Logo
305 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
