Question about GE Washing Machines
Rinse cycle and cold/cold temp are not working
These things are not working; 1. cold/cold in temp. 2. rinse cycle the machine wash and stop at "rinse" cycle. thank you
  • 144 Answers
You either have a faulty cold water inlet valve or you have the cold water hose connected to the hot water inlet valve. Cheers
Posted on May 15, 2009
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
I have centrex washing machine 4.5 kg, the problem is it stops after washing. it doesnt rinsing the clothes stops at this point.
It could be that the cold inlet valve is faulty.. Your machine will rinse with cold water only and if the inlet is faulty then it won't fill for the rinse cycle. This also means that the wash cycle, if set on 'warm' is only getting hot water. Set the wash temp to cold and see if the machine will fill. If not, the cold inlet valve is the problem. You'll need to replace the inlet valve which may be a double unit with two hose connections Best to call a tech..Good luck Nomess (Please take a moment to rate this answer)
Jul 18, 2010 | Washing Machines
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Rinse cycle is not starting after wash cycle. I have to manually turn the knob and it won't start until just before the spin cycle.
inlet valves working correctly are you getting hot and cold water entering the tub ?start the machine and switch from hot to cold and make suire there is both temps available there is a thermister on some washers that read the temp of water cold is required for most machines to rinse ..the therms are mostly located on the inlet water valve inside the machine.
Aug 10, 2009 | Washing Machines
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
My hoover optima washing machine model no. HNF 6127 keeps stopping when it gets to the rinse cycle
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
Dec 16, 2008 | Hoover Washing Machines
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Washing Machines Logo
213 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
