Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a evinrude 3.3hp outboard that starts and runs sweet for about 5mins then starts surging and stalls. tank is clean fuel lines good took carby out and it looks good no dirt in it ,please help me as im keen to go fishing but dont want to paddle the boat home again, my arms are killing me.
    Problem Solver:
  • 14 Answers
Are you positive that all the fuel lines are good.and the primer ball is good? i have had a problem also like that and it turned out that there was some dry rot in the line that would make it **** air.this may be your problem...
Posted on May 15, 2009
Hi i once had same problem with my johnson it was a small thermostat that was partially blocked and cut the engine once it heated it seemed very like a fuel prob at the time but that is what was up tight lines
Posted on May 18, 2009
Have a 1986 Evinrude 8hp outboard motor. Starts on first pull and idles fine but seems to lack acceleration and top speed. What can I check?
rubber or other bits in the carby main jet and other circuits
rubber components from the tank to the carby including the fuel pump break down and end up as rubber grit in the small holes
Jul 06, 2017 | Boating
1989 Evinrude 15 hp E15RCEC Outboard Motor starts but won't stay running. what could be the problem Tried to clean carburetor, didn't work.
depending on how often you used the engine
problems include :-
dirt ,corrosion, rubber bits in the carby---fix is to have the carby professionally cleaned and overhauled
rubber from the fuel hoses disintergrating and causing problems in the carby, the pump valves
the rubber diaphragm in the pump is failing and not producing enough fuel to keep the motor running
the vent on the cap of the fuel tank is still closed creating a vacuum in the fuel system
it would be a good idea to replace all rubber hoses from the tank to the carby, overhaul the fuel pump, and have the carby professionally cleaned and overhauled
if you pull off any rubber hose and get a black stain on your hand ,that is rubber failing.
Aug 22, 2015 | Boating
2001 mercury outboard 25hp 4sroke electric start. will not ldle. l have replaced fuel pump and had carb serviced at dealer. l have replaced the fuel filter twice. l can start with fast ldle easily and drop...
did you mop out the tank , fuel lines and fuel pump etc as water is bad news in a 2stroke ? when in water run engine and set the tickover ON THE CARB throttle stop ! see if it goes in and out nicely just above stalling , you might have to clean the carb again if water in tank !??
Sep 01, 2013 | Boating
30 hp evinrude outboard, running full throttle, then surges as if running out of gas. Will conk out if not taken back to idle. Whats causing this?
Sounds like air is getting into the fuel line. If you have a squeeze bulb primer check to make sure that it stays firm after you run it a bit. I had an air leak on a clamp attaching the primer bulb to the fuel line and the same thing happened to me. When the engine starts to cut out squeeze the primer bulb and see if it starts running better, if it does then you probably do have an air leak in the line and it is losing it's prime. Hope this helps!
Feb 19, 2013 | Boating
I have a 1989 evinrude outboard 225,that shut downonme on my way in. after my tow ini waieted a moth and turned the key again. itwould not start. after 5 minutes of random tries, it started and ran for 30...
check for water or contaminants in the fuel tank and carbys. If a fuse was gone it wouldnt let it start again.So you must have spark, which only leaves the fuel system, unless it is internal engine damage or wear
Apr 25, 2010 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
1990 suzuki sierra - stalling,
Yes your snorkel should have the right size for air to come-in, hope you have the right diameter, but snorkels will not seriously affect your vehicle substantially.
It could be that your fuel system is dirty. I would go for having those carbs cleaned but before you do this, I would advise you to clean your gasoline tank of rusts, water then blow those fuel lines with air to declog, change your fuel filters, if you do a lot of offroading, put two(2) fuel filters, first filter goes just above the gas tank, beside the chassis, the second will be place before your fuel pump, inside your engine compartment. have those fuel pumps cleaned too, check for leaks and moistures on your fuel hose and lines. if you have done all these, and nothing happened, check for strong sparks on your plugs, it could be that they ready fouled up.and check on your igniton coil,
Nov 20, 2008 | 1990 Suzuki Samurai
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
630 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
