The washing machine finishes the cycle, but in the end, the red light keep lighting and other two as well. The one for Iron and the 1200 and 600 spin lights. The cycle is finished, but because these items are lighting, I cannot open the door and I have to start the cycle again and again...
Turn the machine off at the mains, after two minutes the door should release from the auto lock, but your pcb (printed circuit board) is knackered start saving.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
