Question about Singer 8280 Mechanical Sewing Machine
When i use sewing cloth in backside the thread will too loose then i use tension tight it correct in 8 number but manual book says 4 or 5 is correct wat can i do help me
  • cvbasanthi May 23, 2009
    yaa thanks u
  • 128 Answers
Unthread your machine and set the tension to 4.5. rethread your machine up to the needle and then put the presser foot down. If the thread pulls hard, your machine is threaded right if it pulls easily, the thread is not thru the tension wheel correctly.
Rule of thumb:: loops on the top, problem on the bottom.
loops on the bottom, problem on the top.
Posted on May 21, 2009
    Problem Solver:
  • 4 Answers
Different fabrics require different tension. The fabric you are using seems to require a tension of 8.
Different fabric textures, thread, needle, lubrication, etc. can all affect the tension required to sew even stitches.
Posted on May 22, 2009
Fix tension on Singer 4552SW
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight--if tension is too tight back
off one number or letter at a time, if thread is too loose increase
one number or letter at a time till you get the correct stitch
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8.also check to make sure the top thread has not come off the thread
take up lever
if you don't have a manual, & want one, singer has a free pdf
manual to download
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 4552) do not put in
the sw
Click search
Jun 05, 2012 | Singer Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I am trying to make a rag blanket and the tension on my machine loops on the underside. I am about ready to throw it in the ditch. How do you fix the tension on a 9410 singer machine?
How to fix the tension on 'any' sewing machine. I may know how (family in the sewing business for 50 years-all now retired).
To begin with:
1) Put in a new needle;
2) Re-thread the top thread;
3) Lower the foot;
4) If the needle threads from front to back (or r. side to l. side); begin pulling the thread through the needle in the direction it threads, while slightly tightening the top tension knob, wheel, or other tightener. The tension on the top thread should bend the needle quite a bit, without breaking it (for cotton material sewing). If you're sewing a lighter fabric, the top tension should be slightly looser;
5) Once you have the top tension adjusted, re-thread the bobbin case, with the thread coming to you, out of the bobbin, having the thread escapement on the 'top,' while the bobbin case is in your right hand, and the bobbin is visible on the left side. Your instruction book may say the opposite way, but this is really the correct way to do it, as the new threads have many knots in them, and the bobbin case will stay correctly threaded doing it this way; next,
6) loosen the little screw on the flat spring, that presses against the thread on the thread escapement of the bobbin (if it is currently tight);
7) If the thread is easily pulled through the thread escapement, slightly tighten the tread, so a firm pull is needed to bring the thread out of the bobbin case. Not to tight though (or you will get loops on the bottom of your seam. You may have to tighten a little, or loosen a little. The 'knot' of each stitch should be in the middle of the cloth. If the bottom tension is too tight, the knot will be on the bottom; if it's too loose, it will be on the top. When it's just right, it will be in the middle;
8) When you change weights and types of fabrics, you may have to re-adjust your tensions; but, the process is the same.
Just remember: Always begin with a new needle, and always 're-thread' your machine.
I hope this helps.
P.S. My father set up many of the Viking dealers on the East side of the Mississippi. I worked in the business all the time I was going to school, and a couple of years after the service (early 60's). I used to 'dream' about sewing machines, and finally got out of the business, but I still fix machines for my family.
Good Sewing, and
God's Blessings,
J. W. Stevens
Nov 03, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
The tension is off on my machine. The needle thread keeps pulling so tight that it snaps, and the bobbin thread is so loose that I'm getting loops on the backside of whatever I'm sewing. I thought that...
Loops on the backside mean there is no tension on top ,if the top of the sewing l;ooks good then the bobbin tension is correct make sur eyou are threading the top thread correctly
Aug 30, 2008 | Singer 7444 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
173 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
