Question about HP PSC 1510 All-In-One InkJet Printer
HP PSC1510 PAPER JAMS
HI THERE I HAVE THE ABOVE PRODUCT AND IT IS CONSTANTLY JAMMING PAPER . THERE ARE NO OBVIOUS PAPER JAMS AND I HAVE CHECKED AS FAR AS I CAN INSIDE . THE ROLLERS ARE FREE FROM OBSTRUCTIOIN ALSO. I HAVE DOWNLOADED THE CORRECT DRIVERS AND REINSTALLED AND FOLLOWED THE INSTRUCTIONS FROM HP. I.E. SWITCH OFF FOR 30 SECONDS AND MANUALLY SELECT THE PAPER SIZE AND ALSO USE NEW PAPER WITHOUT ANY DAMAGE. ANY OTHER SOLUTIONS BEFORE I CHUCK IT IN THE BIN? REGARDS ROSE
  • Anonymous May 26, 2009
    is is possible for someone to translate this response as i do not speak spanish? regards
    Problem Solver:
  • 6 Answers
Verifque o mecanismo de tracçao do papel esta limpo.se estiver verifique se a patilha que esta qao lado da servic station esta paretido
se estiver nao ha nada a fazer se nao a troca dess patilha
Posted on May 15, 2009
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Xerox 5030 jamming
clean all pick up rollrs and check all paper paths
Dec 12, 2013 | Xerox Office Equipment & Supplies
Says paper jam and there isnt!
It is possible that even though there are no full sheets of paper jamming the printer that some torn bits have been left behind. You need to make sure that cleaning is complete.
Visit this site for full details:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00212225&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=422000&key=null
Preventing paper jams The following recommendations can help prevent recurring paper jams in your HP product.
  • Before loading paper in the tray, hold the stack of paper, and then tap the bottom edge on a flat surface so that the stack is even on all sides.
  • Make sure that the length and width adjusters on the tray are correctly positioned, and then push the stack of paper forward until it stops in the tray. CAUTION: Do not force the paper to move too far forward in the tray.
  • Do not overload the tray with paper.
  • Only add paper to the tray when the product is not printing.
  • Make sure the HP product supports the paper type. See the documentation that came with the HP product for more information.
  • Do not print on paper with paper clips or staples attached.
  • Do not use paper that is bent, torn, dusty, damp, wrinkled, curled, or paper that does not lie flat.
  • Use only one type of paper at a time. Do not mix different types, weights, or sizes of paper.
  • Do not use paper that is too thin, too thick, or too glossy for the product.
Cause The following factors can cause paper jams:
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
I hope thihs is helpful.
Dec 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
Paper jams too often and for no apparent reason. This time tore paper and therefore unable to unjam!
To clear the paper jams always follow the instructions from the manufacturer, here is the support page from Brother website.
Also, sometimes when I get paper torn inside, I use a pair of long-nose pliers to remove it, but be careful not to damage any parts inside the printer.
If the printer is jamming constantly then that means you have a hardware issue in there. Look carefully where is usually jamming and see if you have a clip that stops the paper or a roller that's not pulling the paper and try to fix it or replace the faulty part.
Dec 02, 2010 | Brother HL-2040 Laser Printer
My HP4100 DTN is continually having paper jams for no obvious reason. What can I do to resolve this? (I mean, I know how to resolve the jams, but how can I make sure it does not jam all the time)
Old age printer, prepare to replace the parts.
Step 1: Clean all paper path sensor, replace paper pick up rollers, seperation pads, check with out duplexer unit..
Step 2: Even paper jamming replace fuser assembly..
Step 3: Check with duplexer unit, clean deolexer sensors & rollers..
Nov 23, 2010 | HP LaserJet 4100dtn Printer
HP 5550N, HP550DN & HP3005N having issues with paper jamming in the above printers. Is there a way of checking paper settings on the printers?
no. i think the pressure roller of your printer was to soft already normal call for that item is lower roller and heck the sensor of the fusser assembly
Feb 10, 2010 | HP LaserJet 5500 Printer
No charge on the ETB and or paper, Causing paper fold and jams. Any ideas o brainy ones?
No idea what no charge on ETB/ Transfer kit or paper means?
As far as the jamming with folds? means there is an obstruction in the paper path. Check for labels, bits and pieces of paper etc. Check the paper pickup assembly "paper guide" it often pops out on one side when the paper tray is pulled out roughly by that troubled angry employee. Old fuser that has been reset instead of replaced can do that also. Also check feed rollers they shoud not be slick if they are you will get frequent paper jams.
Sep 04, 2009 | HP LaserJet 5550 Printer
Just bought the product and it is already not working.
Check the paper setting in tray. May be slanted and causing it to pull paper in un-even, this will cause jams. Old, wrinkled paper will also cause same problems.
Feb 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jamming
tell me where it jams so that i may help you! brother tec
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Xerox 6100 laser - paper jams if paper tray low on paper
There could be two things. First, be sure the paper tray is not binding. The metal plate in the middle should spring up easily. The friction pad should be firmly attached to the tray, but not extending over the metal portion. The second thing would be to clean or replace the feed rollers. They are inside the machine above where the tray would sit. Since the tray feeds when full, I don't think you have a clutch problem. Let me know how it goes.
Jun 10, 2008 | Xerox 6100/DN Laser Printer
HP PSC 1510 All-In-One InkJet Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
