Question about Fujitsu Siemens Lifebook C2230 Notebook
Display of the Laptop is not coming at all
FUJITSU Computers Siemens C Series Lifebook Display IC of Motherboard seems faulty. Rest of the laptop is functional but the display of the laptop is not coming at all. Plz give technical advice. Thanks
  • Fujitsu Siemens Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 15, 2009
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
Nov 18, 2015 | Fujitsu Siemens LifeBook Computers &...
Turn off snooze function
I'm a bit confused by your terminology, "snooze" function? We are talking about a Fujitsu Siemens LifeBook A Series Laptop, Correct? If your referring to the Sleep or Hibernate settings, Open the Control Panel, select Power Options, you didn't post your OS, so here's a Win 7 solution, set to High Performance, select Change Plan settings, under Plugged in, set Display time and set Sleep to Never, select Change Advanced power settings, go through the settings one by one set to your preference. Sleep and Hibernate to Never.
Apr 25, 2013 | Fujitsu Siemens LifeBook A Series Laptop...
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Need to remove a keyboard from a Fujitsu model N6110 laptop to clean it from spilled wine. Which screws on back need to be unscrewed to allow this? And are there any catches on the front to remove?
remove-keyboard-fujitsu-laptop-800x800.jpg Remove the Keyboard on a Fujitsu Laptop
Fujitsu makes several series of laptops, with multiple models in each series. Some Fujitsu keyboards are attached with only a few tabs and can be removed with little hassle, but other laptops require more steps to remove the keyboards.
Difficulty:Moderate Instructions Things You'll Need
  • Flat, hard piece of plastic
  • 1Prepare a clean and organized workspace.
  • 2Turn the laptop off. Turn the laptop over and slide the battery switch to pop out the battery.
  • 3Turn the laptop back over and remove the keyboard bezel, the thin piece of plastic directly above the keyboard, by prying it up with a small flat object, such as a hard piece of thin plastic.
  • 4Lift up the keyboard and flip it over to rest on the mouse/palm rest.
  • 5Disconnect the motherboard connection by carefully pulling down on the two tabs on either side of the connector. After the connection is unlocked, gently pull the cable to disconnect it.
  • 6Remove the keyboard.
Tips & Warnings
  • Discharge any static electricity by touching a metallic surface before working with your computer, to avoid damaging sensitive circuits.
May 20, 2011 | Fujitsu Siemens LifeBook N6110 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Laptop display not coming. only green light comes up.
Either your motherboard is fried or your lcd is out. Maybe try and connecting to a different monitor and press CRT and F8. If it comes up on the screen your LCD is gone. Also see if the HDD light on the laptop is coming on. It has a symbol of a cylinder beside it. If that's not on, then your motherboard is fried.
Sep 04, 2009 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
No sound drivers
If you have the installation CD of your motherboard try to browse the CD...usually the sound
driver is already there.
You just need to install again.
Rate this if it is useful!
Jan 15, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu Siemens Lifebook C2230 Notebook Logo
774 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
