Question about Samsung Digimax L730 Digital Camera
Processing for 7-10 seconds
Sometimes after i take some pictures, my digital cam needs 7 to 10 seconds processing to save the pictures....i have no idea why!!!!
is that a processor issue?
  • derej May 15, 2009
    my memory card has 1 GB in size, and even if it is empty, i am facing the same issue.
  • 51 Answers
Yes this is generally a processor issue....you can still try using a diff memory card...sometimes that may help
Posted on May 15, 2009
Whenever i use the usb cable to put photo on my computer i lost same of the picture ,when i am looking through the picture between every 3 photo a''! picture error'' come up.
There must be a software of some kind on your PC that modifies those pics in some way when you connect the cam (or maybe u edit the pictures :) ). If any picture on the cam is edited and saved, the cam will not detect those pics again.
Mar 22, 2011 | Olympus FE-26 Digital Camera
Sometimes pictures show up on memory card of GE x5 cam. sometimes they don't. what could be the problem?
You have an internal memory and memory card selection on your camera. If you have it set on internal memory you can take photos but they won't show up on the memory card unless you save them over to the card. Change your settings and this should fix the problem
Jan 02, 2011 | GE X5 Digital Camera
When i put it in auto and take a picture is says processing and turns off, when i put it on again there is no picture. i have changed the battery and have two new sd cards that should be compatible
dear sir
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusteddevices...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur cam software from the nearest samsung care,it also updates your cam software
take care...thank youu
Oct 08, 2010 | Samsung NV10 Digital Camera
I dont know how to transfer the pictures on my olympus camera to the computer
Is this camera a camera with a memory card?
Transferring picture is a very simple process all you need is to get a card reader.
Then you place the memory card of your cam in the card reader and is the pc adaptor .
It will open on your pc as a pen-drive.
follow the option to copy photos then go to >My Computer > there should be a removable drive, then click and open it and keep clicking on the folder till it brings you to a picture directory. From there you can just copy and save photos.
Thanks,
Dec 10, 2009 | Olympus FE-170 Digital Camera
Not all pictures are being saved on Memory Stick
try searching the stick for other folders. sometimes the camera will create seperate folders due to res settings.
Jun 01, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
How do i save pictures to my media card?
Go to manufacturer's website. Find cam and dowload manual in pdf form (it should be free). The digital cams I've had always save the pic to the card instantly. The cam may automatically be set to save to the internal memory.
Jun 22, 2008 | Gateway DC-M42 Digital Camera
Auto reset following each picture shot
Well most digital cameras are not equipped to allow to take a lot of action photos or just snap off various pictures of the same subject in a relatively short time. The models which are ill-equipped require more time between shots to save the image to the memory card. Just imagine the time it takes to save something on a disk. Keep in mind that the burst mode allows temporary storage of images. This way, you could take as many pictures as you can in no time. With the Nikon Coolpix 4300 Digital Camera, you can expect to find a shutter speed of 1/1000 to 8 seconds. One more camera feature include a Self-Timer mode, which provides a three- or 10-second delay between the time the Shutter button is pressed and the time the image is actually captured... Good luck!
Oct 23, 2005 | Nikon Coolpix 4300 Digital Camera
What are defect pixels?
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels. Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue. Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes. If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair. Notice the green defect pixel near the center of this image.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels. Notice the green defect pixel near the center of this image. Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue. Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes. If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Samsung Digimax L730 Digital Camera Logo
65 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
