Question about Sony VAIO VGN-A160 PC Notebook
Everytime I run the Giga Pocket software, it warning flash states that the laptop in not yet attached to the port replicator, but it already is attached. I so wanted to watch my TV and Cable programs in my laptop what do i do
VGP-PRS20 port replicator stopped working
I haven't use replicators much but the one on My dell is still working.
I will suggest to remove the laptop(you probably did already) and then insert a USB and see if Windows says anything about it, do the same with the other components. If nothing works then I think the unit is bad or the connector on the back of the laptop is bad.
Of course if you had a similar replicator you can test your laptop and see if its port is bad.
Jun 07, 2014 | Sony VAIO Notebook
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    Sony Vaio RS-530G. Have recovery disk. Did recovery a few years ago but "think" did not install "giga pocket," but now want it installed. Probelm is, after loading recover startup it asks for disk 1. ...
    Running your install disk will place a new OS on the drive and if what you want is on the disk, that as well. Make a backup of your data first then restore it all.
    Jul 24, 2017 | Sony VAIO PCV-RS530G PC Desktop
    My D400 overheats and screen freezes when hooked
    The biggest issue docking is airflow. With the system docked, airflow is restricted.
    Might look at ways of improving airflow.
    May 25, 2010 | Dell Latitude D400 Notebook
    Old software need new for 7570 on my laptop with vista.
    try a site called utorrent, they have everything and its free, its really easy it sets itself up automatically than you can download anything. try it out.
    Aug 07, 2009 | PfaFF Creative 7570
    Serial port on dell D600 will not transmit data to device
    boot to the bios (system setup).. locate serial port there and make sure it is turned on
    Mar 18, 2009 | Dell Latitude D600 Notebook
    Dual monitors: DVI and VGA not supported simultaneously
    It looks like this a problem for the Port replicator III, not II, right? I'm not an expert on port replicators, but if you have even an ok video card, it should work fine even running all three...
    Feb 03, 2009 | Toshiba Advanced Port Replicator III...
    Can I use a 1978u replicator with my 8100 if I remove the locking arm?
    try to turn it on ... it should have no problem with the "electronics"
    if you got message that the docking is not compatible, then you will have to flash your notebook bios to the latest 8100 BIOS.
    If same case still happen after updating your BIOS, use C840 bios (which AFAIK will not harm your notebook). It will then read the docking/port replicator correctly.
    Both BIOS can be found here
    Give it a shot ...
    Sep 25, 2008 | Dell Inspiron 8100 Notebook
    Sony Giga Pocket, error: GP666-computer pcv-rs 430G
    I had this problem and I renamed the GigaPocket V5 directory and restarted Giga Pocket. No more problems with GP666, now I just need to learn how to re-import the old videos into the cabinet.
    Wingblur
    Mar 25, 2008 | Computers & Internet
    When I start Giga Pocket I get an error: gp666 cannot launch-Giga Pocket data base might be damaged. I have re-booted, reinstalled and loaded Giga Pocket update utility 5.5. Verified that Vaio media video...
    This one took me a while to figure out as I had the same problem.
    The answer is rename/delete the D:\GigaPocket directory and restart GigaPocket. It will regenerate the directory and will work fine....or at least mine did.
    Have fun
    Wingblur
    Mar 22, 2008 | Computers & Internet
    Sony VAIO VGN-A160 PC Notebook Logo
    104 people viewed this question
    Top Sony Computers & Internet Experts
    Martin Murray
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
