Every ten miniutes my cpu fan is running high speed
    Sergeant:
  • 186 Answers
It's good.*********** board and CPU has a smart cooling technology that's why this happen.
No needs to worry about that.
Posted on May 15, 2009
Does not boot, no beep, no display, fans running on high speed
Try blowing the dust out of the inside, around the vents, around the fans and by the cpu and heat sink.
Also remove the fan as it sits on the cpu and heat sink. Then remove the heat sink that sits on the cpu, then remove the cpu by releasing the latch on the side of the bay it sits in (remember how the cpu goes back into the bay). Now clean off the old dried up thermal paste on top of the cpu and on the heat sink that sits on the cpu. Put the cpu back into the bay and secure the latch. Apply a fresh coat of Thermal Paste to the CPU and Heat Sink. Put everything back together then reboot.
If the thermal paste has dried or is too thin to keep the unit cool it's like metal touching metal and shorts out the system so it can't boot.
May 31, 2012 | Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
Cpu fan running high speed for acer power fv 519 1gb ram, vista operating system,
i have acer power fv desktop win 7 1gb ram ,CPU fan running high speed
Jan 22, 2012 | AcerPower FV PC Desktop
PC runs great until you power completely off. The it will take several tries of power on attempts. It will not start with the CPU fan coming on high speed. Must keep trying until low speed is heard. I...
Sounds like a problem with the power supply based on what you've written. Could be motherboard too, but Power Supply is usually the culprit.
I'd swap it out to test ;)
Jan 01, 2011 | HP Pavilion a450n PC Desktop
Fan runs at very high speed
Hello
OK, firstly, if the CPU fan runs at high revolutions, it means that the CPU is very hot. The more heat on the CPU, the faster the fan will run in order to keep the CPU at the safe temp.
Hence, you will have to open up the case and have a look if the CPU fan housing is clogged with dust particles, this is usually the most common cause for the CPU to overheat. If you can see that there is a lot of use stuck to the fan, you will need to blow if off, i use a compressed air cylinder, it works great.
If there is no dust particles visible, you will need to put some new thermal paste on the CPU chip itself.
Try the first option, let me know what happens.
Kind regards
Andrea
Aug 13, 2010 | HP Desktop Computers - Hewlett-Packard...
Is my cpu getting to hot my cpu fan runs in high speed a lot. do i need a bigger fan or my cpu is going bad.
Neither.
Turn the computer off.
If it is a HP laptop, remove the battery.
Disconnect the AC power.
Buy a can of compressed air, and give your computer a "blow-job",
to blow all the dust away from the heat-sink on top of the CPU,
and also, if it is a desktop, from inside the power-supply.
A layer of dust is a layer of insulation, preventing the heat-sink on top of the CPU from "radiating" the heat away from the CPU. So, your motherboard is detecting that your CPU is "too hot", and automatically speeds-up the cooling fan, to try to move the heat.
Nov 17, 2009 | Office Equipment & Supplies
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
